ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: ShapeShifter on February 05, 2011, 10:20:51 PM
Title: Swapping a 2.0 L for a 2.3 L?
Post by: ShapeShifter on February 05, 2011, 10:20:51 PM
Have you ever heard of anyone doing this?  Is the 2.3 L Aerio engine the same block as a 2.0?  Could be another 20hp......?
Title: Re: Swapping a 2.0 L for a 2.3 L?
Post by: Skyhiranger on February 06, 2011, 06:53:52 AM
I was thinking it has been done.  Or am I thinking of the 2.0 swap in place of the 1.8...which I know can be done ???  If you can't find an answer on here, or the other zuk forums, you might try googling it.
Post by: Freak on February 06, 2011, 01:02:03 PM
The 2.3 Aerio engine is the same block as the 2.0/1.8. I've heard of the Aerio 2.3 done in a Sammy but it should be a pretty easy swap for the 2.0 using the 2.0 intake and Exhaust manifold. The water outlet is on the back of the 2.3 though and may require some modding.
Post by: fordem on February 06, 2011, 01:03:48 PM
I've never seen the 2.3, but the water outlet is on the back of the head on the 1.8 & 2.0 (those use the same head & block)
Post by: ShapeShifter on February 06, 2011, 01:05:58 PM
BTW, I am thinking of doing this on a 2nd gen Vitracka.
