ZUKIWORLD Model Specific Suzuki Forum => Suzuki Samurai (All SJ Platform) 1981-1998 => Topic started by: chocolatemilk on March 02, 2011, 12:34:55 PM
Title: need help engine stutter
Post by: chocolatemilk on March 02, 2011, 12:34:55 PM
I just bought a 87 samurai and it started stalling on me. I replaced fuel filter and it runs better but it still stutters. Any ideas please help. Thank you
Title: Re: need help engine stutter
Post by: hazmat on March 02, 2011, 01:19:29 PM
I got a 86 and 88.  The 88 was doing the same thing. If you still got the stock carb there are vent tubes on the drivers side of the carb under the breather.  Make sure they are hooked up.  Hope that helps you if not check all the vac hoses.  also check the sparkplugs and the wires.  If I think of any thing else will let you know.
Post by: chocolatemilk on March 02, 2011, 01:51:42 PM
Its an aftermaket carb. I replaced the spark plugs and the cap and roter. My freinds think im running lean.
but thank u i appreciate it I will look for any vacuum leaks.
Post by: Drone637 on March 02, 2011, 06:00:06 PM
What type of carb do you have installed?
Post by: chocolatemilk on March 02, 2011, 07:58:19 PM
I think its a weber.it was on it when I bought it.
Post by: Drone637 on March 06, 2011, 01:45:19 AM
Are you seeing the issue all of the time or just during specific operations, like cruising down the highway or once the car warms up?
Post by: chocolatemilk on March 07, 2011, 09:21:20 AM
Its all the time.
Post by: Drone637 on March 08, 2011, 01:29:50 PM
Are you running the stock fuel pump or an electric one?  You might have a fuel delivery issue with either to much or not enough pressure.  It might also just need to be adjusted.
Post by: chocolatemilk on March 09, 2011, 02:30:03 PM
The guy I got it from said it was a new fuel pump. Can I use an electric fuel pump from a sidekick. I have one but I didn't know if it was to much pressure for the carb.
Post by: tipover on March 09, 2011, 08:26:30 PM
you want 3-5 psi.   Fuel injection pump are 40+  Float level? never had a weber but i assume it has a float? hows your timing?
Post by: chocolatemilk on March 09, 2011, 10:15:51 PM
He said that the carb is pretty new I don't really know how to adjust the float or the carb air fuel mix. And I lost my timing gun so I can't check that yet.
Post by: Drone637 on March 10, 2011, 02:52:21 PM
If you are using the stock pump then you will want to put a fuel regulator in between the pump and the carb.  I believe the Webbers run about 2 lb's.
Post by: chocolatemilk on March 10, 2011, 04:42:53 PM
ok i will try that and let u know how it goes. :)
Post by: chocolatemilk on March 15, 2011, 10:49:17 PM
It was my break booster
Post by: Drone637 on March 15, 2011, 11:13:16 PM
Vacuum line hooked up wrong?
Post by: chocolatemilk on March 16, 2011, 01:43:55 PM
I pluged my vacuum line and it ran better. then i changed my booster and it wanted to stall when i pumped the breaks. put my old booster back on and the breaks were better. i took it around the block and the breaks word but now it running bad again. i think the vacuum system is wrong but i dont have a diagram to look at to fix it.
Post by: chocolatemilk on March 16, 2011, 01:51:43 PM
their are a lot more lines on the stock carb then my new carb. the guy used a lot of caps for the vacuum lines that he didnt use anymore.
Post by: chocolatemilk on March 30, 2011, 06:48:22 PM
I fixed it. my adapter plates for my carb were lose. now i just have to get the right adjustment its running a lil rich. thank you all for your help.
Post by: Drone637 on March 31, 2011, 12:29:31 PM
Glad it was something simple.
Post by: Teck543 on April 15, 2011, 11:26:38 PM
Me and my father both have samurais both 88 we had some problems with stutter but he ordered us each a vent tube and they seem to be running fine ever since http://www.zukioffroad.com/Tech_Library/vent_tube.htm (http://www.zukioffroad.com/Tech_Library/vent_tube.htm)
