ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: vw505 on March 12, 2011, 01:09:03 AM
Title: Smog Tips????? It failed!!!!!!!
Post by: vw505 on March 12, 2011, 01:09:03 AM
I am taking my 93 tracker in for a smog check. I have picked up some new plugs, wires, cap and roter. I plan on a fresh oil change also. Any thing else you can think of to help me pass. The Kick runs good i just dont want to risk failing and paying all the extra money to get it to pass.
Title: Re: Smog Tips?????
Post by: wildgoody on March 12, 2011, 01:38:08 PM
Sounds good, take it in good and hot, like just off the freeway, and
fresh gas from a quality station, like Chevron, the big 3 auto makers
are supposed to use only Chevron gasoline for their emissions testing,
they even have it trucked in from out  of state  because there are no
local chevron stations where they are
Title: Re: Smog Tips????? It failed!!!!!!!
Post by: vw505 on March 13, 2011, 02:27:48 PM
I need to get my NO down to 568ppm from 1114ppm! Any tips?
Post by: DonD on March 13, 2011, 02:57:33 PM
This shadetree mechanic says:
EGR
Cat
Timing
Post by: vw505 on March 13, 2011, 03:00:16 PM
the EGR Vac. line was not on when we checked it. I must have knocked it loose when i changed out my plugs, would that give me such high levels?
Post by: wildgoody on March 13, 2011, 04:16:19 PM
EGR reduces NOX, by slowing down the rate of the burn in the cylinders.
Cat will not affect NOX by as much, it mostly lowers HC and CO
Post by: vw505 on March 13, 2011, 04:28:56 PM
Is there anything i can do to clean it before i bring it back? The tracker was not driven far for the past 2 years just 3 miles each way if that.
Post by: Jluck on March 13, 2011, 04:53:48 PM
get a new o2 sensor and clean (carefully) your mass air flow sensor. maybe a new air filter too. :D
Post by: oak_raid on March 13, 2011, 10:12:28 PM
Get you a can of G2P.  My sammy went from ridiculously high NoX to almost 0 after using it.
Post by: wildgoody on March 13, 2011, 11:44:20 PM
A new O2 and MAF will help HC not NOX, clean and check the EGR,
and make sure the vacuum lines are on correctly, the smog guy should
of done that unless you took it to a Check Only station, they aren't
allowed to make any adjustments, at least here in California.
Post by: vw505 on March 14, 2011, 07:40:24 PM
We missed the Vac line off the EGR and ran the test. I have to get my checked at a test only station so i got a pre test at pepboys so see were a was and failed for NOX.
Post by: vw505 on April 18, 2011, 07:12:24 PM
Just got it to pass, changed out the manifold, was cracked in two places, new O2 senser cleeaned the EGR new gaskets. still failed. Then i took it in and got a new cat and went from 1400 NOX to 1ppm !!!!!!!! looking at the old cat i could see why it was failing, i guess the old owner just drove it with the cracked manifold and running it rich killed the cat.
Post by: vw505 on April 18, 2011, 07:14:19 PM
Oh did 2" pipe with a flowmaster i had laying around. Not to bad little more power and sounds good.
Post by: Drone637 on April 20, 2011, 03:27:18 PM
It's amazing how much of a difference you can get by having a working exhaust system.  :)
Post by: Soupy on April 20, 2011, 06:41:50 PM
SEAFOAM... its in the snake oil isle at every parts house. I've used it, it works. pour 1/3 of the can into the crankcase, 1/3 in the fuel tank, then pull a vacum line leading to the intake, with the motor running suck about 1/2 or 1/3 of what is left in the can, turn off engine, let sit 20 minutes. Go for a drive 15 minute drive. Tehn suck another 1/3 into intake, let sit 20 minutes. another spirited 15 minute drive. Then suck whatever is left into intake, let sit 20 minutes. another spirited drive.  Then an oil change.
I've spread the "spirited drives"  over a day .... drive to work, drive for lunch, drive home, change oil at night.
Most of you with think the whole ttreatment is  nutz, but I have had 3 different vehicles fail emissions and then pass after this treatment.  I've yet to see anything bad happen to the motors after this.  Search You Tube for Seafoam and you will see what it does...
Post by: djlantis57 on April 21, 2011, 04:56:41 PM
vw505
I JUST smogged my convertible tracker. No kidding, just about half hour ago. It passed great! The emissions were super low! My other one just barely passed earlier this year.
I used seafoam earlier in the week. Two cans. Sucked almost a whole bottle through the vacuum line coming from the brake booster and poured about half a can into the oil and about a half into my half tank of fuel. Let it sit then drove it. Let it sit again overnight then ran it like hell again the next day and then changed the oil and filter. Then i ran it like hell right before i smogged it so it was definitely warmed up. Can't pay attention to the temperature gauge because it's the CAT that you want warmed up. Usually takes awhile to warm that up.
Did it help? I dunno but the numbers were ridiculously low across the board.
Oh and it didn't smoke like I thought it would with the seafoam. Just left a rather large black streak on the concrete where the exhaust dumped out. The only smoke came from under the hood through a very small exhaust leak on the manifold when I was pouring some down the vacuum line.
Pour a little and let it idle back up then pour more, wait. Repeat until you suck quite a bit into it.
Worked for me. Dunno of the engine just runs right or if the seafoam really worked
Post by: vw505 on April 22, 2011, 07:58:20 AM
Mine faild do to lack of mantance in the past the cat was shot. But hell it works great now gets good milage.
