ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: barlow86 on April 24, 2011, 09:26:48 PM
Title: need help with 86 sami
Post by: barlow86 on April 24, 2011, 09:26:48 PM
alright so I have a 86 sami, with around 230k miles on it.  it was my dd until just recently and I have yet to have any serious problems. I moved houses recently so i had to tow it to the new house,  i jumped it at the old house she fired right up no problem.  put her on the trailer and drove to the new house,  the battery was still dead so i rolled her off the trailer and went to jump her.  did not start.  she spins like the world is ending and i know there is fuel because i can see it being dumped into the carb.  it has a two month old coil, wire set, plugs, cap and rotor.  i looked at the cap there is a little what appears to be corrosion on the inside so i brushed it off,  the dist,  is rock solid so im pretty sure its not that.  anyone have any ideas?  thank you in advanced.
Title: Re: need help with 86 sami
Post by: Riverrat on April 25, 2011, 05:59:20 AM
Sounds like what happened to mine! If it is getting fuel & spark, pull a plug & see if they are super wet?
My stock carb would drown the plugs when hitting a bump |removethispart|@ close to idle speeds!
Would start fine after a few hrs. or over night!
The only change was a Weber carb, & it has'nt happened since!
Just my .02!!
Riverrat
Post by: barlow86 on April 25, 2011, 03:01:43 PM
I have a webber carb, and i let it sit after the first day,  i figured maybe i had flooded it,  but the next day it didnt start either.
Post by: CAMISAMI on April 26, 2011, 10:36:21 AM
Timing belt? just a thought.
Post by: barlow86 on April 27, 2011, 01:39:58 PM
I was hoping it not to be,  but im afraid that it may be,  i had it changed out about a month ago so idk, maybe something was screwed up with the timing,  but my thought is it was running fine the very same day it died and all i did was trailer it 15 miles ???????
