ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: ramdodger on June 03, 2011, 07:32:14 PM
Hey Folks!
I was wondering if the 6 digit serial number on a 1.3 engine should match any of the numbers on the vehicle VIN?
I am trying to figure out if I have the original power plant. ???
Thanks!
Tony
where are the numbers at ? I will go and look at mine.
The VIN is on the left end of the dash and down on the left inside of the cab...where the non clutch riding foot should be. :)
The engine number is stamped on the left side of the block next to the trans.
I ask because wifey wants to rebuild original engine instead of using it as core on a long block. I checked to see if it was matching, and it does not that I can tell.
Yeah, its her ride. That I blew up. Thats another story. >:D
Well I took a rag on the end of a stick and found them and they are not even close, the first three numbers start off with 111,
it is a Big block 1324 cc, Wow.
I will make the observation that there is no tie between the engine number and the VIN...
notice I didnt make an 'assumption'. 8)
Thanks for your help Mr Fuelish!
no prob.
The engine # may still be a matching #, it just doesn't co-ordinate with our VIN's
I'm sure someplace there is a listing with the engine serial #s that shows when
they were built, and that corresponds with the age and VIN of the trucklet
the 1324cc is the displacement there is a stamped number i dont remember what side i will look in the morning
I don't recall any of the numbers matching. They probably wouldn't as the block was built by Aisin and not Suzuki.
I also would not rebuild a 1300cc engine. I would rebuild a 1600cc 8-valve or find a good use one. They give about the same 1600cc but the additional 25% more HP and torque makes the Samurai mucho street friendlier.
Eric has gone with a high performance 1.3l in the past, seemed to like it:
http://zukiworld.com/month_060101/feature_reynolds_01.htm (http://zukiworld.com/month_060101/feature_reynolds_01.htm)
SammyPro can help you build a 1.3l that will keep up with a 1.6 without having to perform the full swap.
http://www.sammypro.com/ (http://www.sammypro.com/)
So it depends on what you think is easier. :)
You make it sound like swapping in a 1600cc is a big chore. :laugh:
The 1300cc is a good engine, but it just doesn't have the power for highway use. Especially if you have larger than stock tires.
If I was just planning on putting around a small town (below 50mph) and rarely see the highway, I would stay with the 1300cc. Otherwise, 1600cc 8)
