ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: konazuki808 on June 11, 2011, 01:01:02 PM
Title: just bought my first samuri
Post by: konazuki808 on June 11, 2011, 01:01:02 PM
live in hawaii and just bought my first samuri got a million questions just had to check out this forum want to keep it stock for a wile then maby go with a little lift but realy want to find out how to gain more horse power out of this cute 1.3L
Title: Re: just bought my first samuri
Post by: Drone637 on June 11, 2011, 02:10:11 PM
Congrats!
A tune-up is always first, then most people will go for a 2" exhaust.  Which Island are you on?
Post by: konazuki808 on June 11, 2011, 03:01:51 PM
live on the big island tune up for sure what about a less complex carb like a webber with out all the vacume hoses plans for headders and pipeing for sure . well so far this 88 has 48,000 original miles but it was sitting for 6 years got a new batt alter cleaned out fuel probs and changed oil plugs cap rotor wires next runs cherry but ran into from what i heard is verry common with the transfer cace sticks in the nutral position so i droped the transfer cace and found that when i took of the locking mecinisum there was no rubber bushing so now when it gets positioned in 4 low and back to nutreal it jams saw a polyurithain one for 16 bucks
any way paid 1,500   for it bodys alittle bus but cherry interior looks like it was a real beach cruser my goal is to try and get the most bang for my buck without havin to go all toyota guts doing as much recerch with what i got any suggestions help even better gearing with hp to be able to push some 31s on a 3or 4 in lift
Post by: Drone637 on June 12, 2011, 10:02:58 PM
Webbers are a great swap, as is a Side-Draft conversion over to a set of Harley carbs.  I'll let other people chime in on the best carb out of the two.
To run 31" tires transfer case gears or a lower differential gears will get you most of your power back.  I'm a big fan of putting new gears in the t-case and leaving the front and rear end alone.  A set of 4.8 or 5.8 t-case gears should be just about perfect.
For the lift if you have access to a welder then a SPOA, or Spring Over Axle, lift is the quickest and easiest way to fit 31" tires, but there are a couple ways of doing it.  Just depends on how much fabrication work you can do and how much you want to spend.
For a nice adventure rig some 2.5" OME Springs and 30" tires with a 4:1 transfer case is a great way to go.  Small enough you won't break stuff but big enough to go most anywhere, especially with lockers front and rear.
Post by: Jonny Rash on June 13, 2011, 03:21:39 PM
Heck, since you are in Hawaii and the top speed is something like 60mph right, I would just swap in some lower gears like a 4:1 case gear set.  That would make it easier on the engine to turn even stock sized tires (12% high range redux) and you would have a really killer low range.  I would keep the stock carb and exhaust in place if everything is in working order.
Then if you wanted a little lift later (2" OME highly recommend) you could swap in some 29" tires and still be able to turn them well with the 4:1 case.
Post by: konazuki808 on June 16, 2011, 09:25:36 PM
hey  thanks for the insite just wanted to say aloha to anyone that provides me with info on this project of mine cause it will be a better project with help i plan on keeping it for along time wanted to build a samurai for years my first real offroad experiance was in a samurai and loved it ive owned toyotas chevys and fords but there is something about japanese 4wheel driving looking foward to the build aloha every body.
Post by: MY-UKI-RIDER on June 16, 2011, 11:36:32 PM
Wassssup! Kona, your gonna enjoy it. Takes me where ever I wanna go fishing. here's mine
Post by: konazuki808 on June 17, 2011, 05:34:52 PM
 Thats what im talken about AwwRitte. looks like south side howz da fisshn
Post by: MY-UKI-RIDER on June 17, 2011, 09:59:42 PM
From Maui-Hawaii, Makena Light House: fishing still good out here....caught 3 fish that night ranging from 30- 50 lbs.
