ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: blaster716 on June 26, 2011, 06:08:04 AM
Title: Samurai clutch
Post by: blaster716 on June 26, 2011, 06:08:04 AM
Iam replacing my samurai`s motor with an 8v from a tracker , my question is which cluch do I buy oone for a tracker or one for a samurai , I se that they offer different clutches for the different models. I am planning to use the flywheel from the samuri and was going to order a clutch for a samurai , but now im not sure.
Title: Re: Samurai clutch
Post by: fordguy79 on June 26, 2011, 08:27:43 AM
use a samurai clutch   the 1.6 clutch is bigger i have herd of ppl using them but it's a lot of work the 1.3 samurai clutch goes right in
Post by: Skyhiranger on June 26, 2011, 10:05:04 AM
You have to use the clutch that matches your flywheel.
Post by: blaster716 on June 27, 2011, 03:01:19 AM
Post by: zukwrench on June 28, 2011, 07:36:36 PM
flywheel has to fit transmission. disc has to fit flywheel.....
