ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: kreator on June 28, 2011, 02:09:54 PM
Title: check engine light on
Post by: kreator on June 28, 2011, 02:09:54 PM
1992 geo tracker, which two do I jump to get the check engine to flash ? ???
Title: Re: check engine light on
Post by: bentparts on June 28, 2011, 03:36:19 PM
#'s 4 and 5 I believe, the 1st on top is not used, bottom row jump first two. I think.
Post by: DonD on June 28, 2011, 04:04:41 PM
HTH............2 to 4 on the 6pin
Post by: kreator on June 29, 2011, 08:06:57 AM
Thanks , I will check it out when I get back from the job site .  :)
Post by: kreator on June 29, 2011, 03:35:51 PM
Where can I get a hold of a good manule on the geo tracker ?
Post by: kreator on June 29, 2011, 04:04:07 PM
the light flashes 5 times pause and flashes 1 more   ??? what is it ? thanks
Post by: BRD HNTR on June 29, 2011, 06:00:54 PM
Can't beat the FSM.  Go to ACK's http://www.acksfaq.com/index.htm (http://www.acksfaq.com/index.htm), he has it online.
Post by: DonD on June 29, 2011, 06:20:30 PM
51 is EGR. (From '90 manual)
Post by: DonD on June 29, 2011, 06:44:26 PM
http://www.kick-fix.com/EGR.html (http://www.kick-fix.com/EGR.html)
Post by: locjaw on June 29, 2011, 07:40:27 PM
yeh, you need to take off your EGR and clean that bad boy.
Post by: kreator on June 30, 2011, 07:51:41 AM
 :) correct took off the egr off of the old engine and cleaned it up and all is well !!! thanks guys , now that I got all the bugs worked out I can start on the more important things like building custom lift and bumpers. I will supply pics of all the new parts.
 :)  ;)  :D  ;D
