ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: MY-UKI-RIDER on June 28, 2011, 09:18:36 PM
My 87 samurai light sensor went on.... What does that mean... Do I need to clean my carb? 32/36 weber Or is it something else.
under the dash by the steering colem there's a switch slide it the other way
its not to clean the carb the carb has no sensors if it's a Weber
What is the sensor for??
Sensor - noun - A device that detects or measures a physical property and records, indicates, or otherwise responds to it
Your 87 Samurai has no light sensor - what you are referring to is probably the 'service engine soon' light - it turns on every 50,000 miles - the switch that fordguy79 has told you about should turn it off.
Found it... Much mahalos. From Hawaii
