ZUKIWORLD Discussion Forum => Adventure (Let's GO WHEELING!) => Topic started by: BRD HNTR on July 31, 2011, 09:01:13 pm
We are doing an upgrade to Silverarrow Bowman archery club, which includes new foot bridges. I built a 40' long bridge (out of 6" pipe) to cross over a creek passing through the archery range, and used my Tracker to move the bridge into position. After making my way through the trees and brush, I used the winch & snatch block to lift/drag the bridge across the creek.
(https://lh4.googleusercontent.com/-Z3Jtyq5lEfo/TjYfi4l6TWI/AAAAAAAAABQ/ZlkmVXoyPGE/s912/brdgwk%252520%2525283%252529.JPG)
Then winched it into place.
(https://lh4.googleusercontent.com/-CBBKjUO1tFk/TjYfsDv5EEI/AAAAAAAAABY/xHrqB7mFkv8/s912/brdgwk%252520%2525288%252529.JPG)
Then I had to try and drive out.
(https://lh4.googleusercontent.com/-AcnPFJtDqS0/TjYf21ICjgI/AAAAAAAAABg/AQCqz1N5B74/s912/sttrkr%252520%2525282%252529.JPG)
The work crew had to see whether I was going to get out.
(https://lh3.googleusercontent.com/-4vVns5Fxll8/TjYgBugWTPI/AAAAAAAAABk/rRIh0Vs_YCE/s912/sttrkr%252520%2525284%252529.JPG)
It was a tight fit.
(https://lh4.googleusercontent.com/-IrBdZXeJJ7g/TjYgUliz5uI/AAAAAAAAABs/zvyKU3WAhVo/s912/sttrkr%252520%2525286%252529.JPG)
I did have to use my winch to get out, with all the humus I couldn't get enough traction to climb out. Everyone was impressed with the abilities of the Tracker.
We need to get better meat on those rims. :)
It does need new meats, but just below the last photo it was probably as steep as I had in Moab, only in forest dirt it just dug holes. I had it on two wheels when I was going down in. I thought I was going to take out the mirror then also.
