ZUKIWORLD Model Specific Suzuki Forum => Suzuki Grand Vitara (Gen. 3 Platform) 2006 - 2013 => Topic started by: rerogers on September 02, 2011, 06:58:42 AM
Title: What year GV to buy 06, 07 ,08?
Post by: rerogers on September 02, 2011, 06:58:42 AM
 ??? So I am going to trade in my truck for a GV.  I do need a 4wd for when i go out to my deer lease (It can get real sloppy when wet).  I have been looking at youtube videos and it looks like the GV does well offroad.  Can someone help me figure out what year to buy that will do the best offroad?
Title: Re: What year GV to buy 06, 07 ,08?
Post by: Warn Industries on October 04, 2011, 08:32:08 AM
Someone correct me if I'm wrong, but I believe the 06-08 were nearly the same. I read somewhere that the 2006s weren't available with low-range, but I did a quick search through portland.craigslist.org and found a 2006 (rare V-6 manual, too!) with "4L" on transfer case knob.
In 2009, however, the GV got the 3.2-liter V6.
- Andy
Post by: crewcabrob on October 04, 2011, 10:53:29 AM
I'm not real sure about the low range in 06.
I can sure tell you that if you can find a 3.2l v6 GV, that would be the one to get.  It has the best engine/tranny combo in NA.  We don't get the oil burner here in the states, and the 2.4l is a decent engine but it sure has some heft to pull around.  And it only gets the 4spd auto in the higher level trims.
Beyond my recomendation of the 3.2l engine, the newest GV you can afford is my  honest opinion.
Rob
Post by: Warn Industries on October 05, 2011, 07:26:33 AM
Just an FYI, only the 2006-2008 models were available with the V6 and 4WD, too. The 3.2, although a more powerful engine, is auto only, if that's important to anyone (it is to me!).  8)
Also the '06-'08s weren't available with 4WD and the four cylinder. Apparently, they were in 2009+, though. This is according to http://www.fueleconomy.gov (http://www.fueleconomy.gov).
- Andy
Post by: fordem on October 05, 2011, 09:17:32 AM
I just want to make a comment here ...
What is/was available in any given year is dependent on which country you're in.
Also, as far as I know, the entire 06 and later Grand Vitara range IS 4WD - Suzuki does not offer a RWD or 2WD only version - you have a choice of single mode 4WD (AWD, no low range, no lockable center diff) or four mode 4WD (4H, 4HLc, N, 4LLc) - rumor has it that this will change for the 2012 model year.
I have driven an 07 2.0 four cylinder, auto transmisson with four mode 4WD - so they do exist.
Post by: crewcabrob on October 05, 2011, 11:49:01 AM
Hi,
I'm sorry to point this out, but your information is incorrect.  Suzuki does make a RWD only version in the US.  In fact, you can get a manual RWD base model as well as the rest of the range in RWD with an auto.  There are alos two 4 wheel drive options; an AWD and a 4 mode set up with the low range and nuetral.
Rob
Post by: fordem on October 05, 2011, 12:39:36 PM
Thanks for the correction - it does however illustrate my point - what's available is dependent on where you are - we don't get anything other than the 2.0 with four mode 4WD.
Post by: Warn Industries on October 11, 2011, 08:36:13 AM
I should point out my information was for the U.S. market.
- Andy
Post by: fordem on October 11, 2011, 11:17:44 AM
And we have no idea where the original poster is ...
Post by: crewcabrob on October 11, 2011, 12:00:41 PM
1 post and gone.  A true drive by...
Post by: Warn Industries on October 12, 2011, 08:40:19 AM
Well, I thought I'd take this moment and say you've got a great looking GV! One of the best looking ones I've seen.
- Andy
Post by: crewcabrob on October 13, 2011, 06:47:31 AM
Thank you, I appreciate the feedback.  It's funny what a lift and Wheels/tires will do to a little truck.
Now if you could only help me figure out a way to put a Warrn winch behind the front bumper of my GV, it would look even better!
Rob
Post by: fordem on October 13, 2011, 08:15:50 AM
ARB has a winch bumper should fit that - they have two different ones for the second gen GV
Post by: Warn Industries on October 13, 2011, 08:18:46 AM
Rob
I'm sure you know ARB makes a bumper for the new GV, but it's far from "behind" the bumper. I did find this out of Europe:
http://www.more4x4.eu/afn-winch-mounting-plates-details/381.html (http://www.more4x4.eu/afn-winch-mounting-plates-details/381.html)
- Andy
Post by: crewcabrob on October 13, 2011, 08:45:23 AM
Thanks for finding an english version of that.  I have seen that same mount on other furums and I am interested in it, but all of the sites I found had it in different languages and not english.
I would look at a smaller winch and just make sure I always used at least one snatch block.  For as little as the GV weighs, I even though about a winch in the 4000lb range which is what a side by side Utility would have on it.  I just don't think the electrical on the GV could handle a 9000lb winch nor would I want to pull that much with my little truck.
Rob
Post by: crewcabrob on October 13, 2011, 08:46:39 AM
By the way, the ARB is out for me.  Too heavy and too expensive for me to put on the front of the GV and personally I like the look of the front end right now.
Rob
Post by: fordem on October 13, 2011, 10:48:43 AM
Rob
Given the right circumstances your truck pulling itself could exceed 9000lb.
I've been curious as to how the electrical system on the new GV handles high power electrical loads - the charge system is under ECU control and the ECU monitors the electrical load by measuring the amp draw through the main fuse block.  A high power load, such as a winch, would have to bypass that fuse block, so that ECU wouldn't be aware of it, and as a result might not ramp the output up to compensate.
This "feature" would/could also impact an alternator upgrade - would your high output alternator have to be compatible with your ECU (or vice versa) and how easy would it be to locate a suitable unit?
Post by: crewcabrob on October 13, 2011, 11:44:23 AM
I always had in mind that I would need to use at least one, maybe two snatch blocks for pulling out of a sticky situation.  Even with a 4000lb winch, I would be able to have the pulling power of 12000lbs.  It would certianly need to make use of a line extension, a couple of shackles as well as two blocks.
One nice thing about the smaller side by side utility winches is the lower amp draw.  For the few occasions that I would ever need a winch, I think a set up like this could be perfect.  It would be small, light weight, affordable but yet still be there if I needed it.
I see a lot of the Aussie guys running dual batteries.  I don't think I will ever get to the point, but for larger loads on the electrical system it sure would be nice to have.
Rob
Post by: Warn Industries on October 14, 2011, 10:17:23 AM
Rob
So long as you keep the engine running while winching, you shouldn't have issues with the charging system.
- Andy
Post by: fordem on October 14, 2011, 10:46:34 AM
- Andy
Does this take into consideration what I mentioned earlier about an ECU controlled charge system?
I don't know how common these systems are, but I do know they are not unique to Suzuki as I recently picked up a Mitsubishi Pajero iO (a compact SUV not offered in North America) which has a similar alternator & charge system.
