ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: tracker14 on September 10, 2011, 01:38:17 PM
I have toyotas 3 linked under my kick and my pinion angles are still to much. im looking for the easiset solution to fix this now and i was wondering if anyone had rotated there t-case with a adapter plate to drop the slip yokes down.
Are you using a Toyota CV style drive shaft? If so you can re-do your rear axle to have the pinion point directly at the t-case. You only need to have the two level if your using U-Joints.
