ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: airmanwilliams on November 03, 2011, 12:43:04 PM
Title: 1.6L 16V 5spd behind a 2.0 motor ?
Post by: airmanwilliams on November 03, 2011, 12:43:04 PM
Hey guys I have a guy interested in my doubler setup that is mated to a 5spd trans that was behind a 1.6L 16v but hes asking if it will bolt up to a 2.0 motor and I have no idea. Can anyone help me out please?
Title: Re: 1.6L 8V 5spd behind a 2.0 motor ?
Post by: Drone637 on November 03, 2011, 04:08:46 PM
It will bolt up, but you need a flywheel from Trail Tough to allow the clutch to work.  A 1.8l flywheel might also work, but it hasn't been tested yet as far as I know.  You will also need to make new engine mounts, we are running a 2.0L in Project Trouble.
Post by: airmanwilliams on November 03, 2011, 04:40:46 PM
thanks drone seems I typed it wrong in the title but again its just the trans and tcase from a 16v motor thats going to be attached to a 2.0L
Title: Re: 1.6L 16V 5spd behind a 2.0 motor ?
Post by: Drone637 on November 03, 2011, 04:46:49 PM
It's all the same.  Just give Trail Tough a call and they will hook you up.  :)
Post by: ebewley on November 05, 2011, 03:21:11 PM
I've got a 1.8L engine bolted to a 1.6 transmission. That may help you??? I believe the 1.8 flywheel parts will bolt to a 2.0 and 2.3 which would make the following statement true... :) There are factory non-modified parts to bolt that combo together you'd just have to do some junk yardin' to find them.
Hope that helps.
Post by: Drone637 on November 05, 2011, 06:16:05 PM
Did you ever try putting a starter on and see if it will fit?
Post by: ebewley on November 06, 2011, 11:17:17 AM
Hey Kris - that's a good question... I'd have to say, 'maybe'... It was part of a project I did literally 10 years ago and I don't remember. I do believe I bolted it together and had the started on there because I seem to remember having battery cables on??? but may be mistaken. The engine and tranny combo are still on a pallet in storage after I aborted and sold off the project. So, that's what I know. Do you know something? :)
http://www.zukiworld.com/month_010102/feature_project_niceride_01.htm (http://www.zukiworld.com/month_010102/feature_project_niceride_01.htm)
Post by: Drone637 on November 06, 2011, 12:06:32 PM
No.  But if you still had that tub my cousin is looking for one to chop and drop to make a roadster out of. :D
Post by: ebewley on November 06, 2011, 01:20:49 PM
Sold it... BUT I have a much cooler '82 hardtop (metal dash) that's forsale. It even has the 1.0 liter. Perfect for a .... what? a roadster out of a hard top? Why not start with a soft top? Chop and Drop, yeah I can see that.
Post by: Drone637 on November 06, 2011, 11:11:59 PM
He wants to leave the top on, do a rat-rod style setup.  The Sammy is nice because of the flat windows, much easier to cut down.  He has a soft top now, but really wants a hard top.  PM me how much your looking to get.
Post by: honkey_2.0 on November 18, 2011, 09:23:49 AM
to answer the starter question you will need a stock 16v starter.. I have a 2.0 in my 94 jlx runs great!!!! any ?'s you have about the swap I just got mine on the road.. pm me if you run into any bumps along the project.. also I am still trying to get pics up.
