ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: jga154 on November 03, 2011, 06:48:32 PM
Title: Speedometer cable removal
Post by: jga154 on November 03, 2011, 06:48:32 PM
86 Samurai; Can the speedometer cable be removed without draining the fluid first or will all the fluid leak out?
Thanks,
Jim
Title: Re: Speedometer cable removal
Post by: Skyhiranger on November 04, 2011, 08:13:59 AM
Yes, you can remove just the cable from the tcase and no fluid will leak out.  Remove the bolt from the bottom part of the tcase speedo assembly, wiggle the cable and it should slide right out.
