ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Breeze-O-Top on November 21, 2011, 05:18:16 PM
Title: Carb Removal Tips
Post by: Breeze-O-Top on November 21, 2011, 05:18:16 PM
It looks like I need to remove and replace my stock carb on my 87 Sami. I narrowed down my poor running to the carb. Petroworks has them for about $585 for a rebuilt unit. Is that on the high side? I trust them to do a good job. I met the rebuilder and he seems to know what he is doing.
Second issue, is there a link on getting the bowl of spaghetti of hoses off in order (tips), and I can only see two of the nuts for removal.
Any advice on the carb removal?   ???
Title: Re: Carb Removal Tips
Post by: weldboy on November 21, 2011, 08:15:58 PM
You have 2 nuts on the battery side which you probably see, and the other 2 are toward the valve cover side under the vacuum hoses. I cut the open end part of the 12mm wrench to make it shorter and easier access to turn the nuts. For vacuum hoses you should have a diagrahm on the underside of the hood or you can find it at Ack's faq website. It really looks alot worse than it is. Hope this helps. ;D
Post by: Breeze-O-Top on November 23, 2011, 01:59:10 PM
I found the location of the four nuts, I had to move the hoses around to spot them. Still looking for a good link to remove the carb.
