ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: builder1 on November 22, 2011, 10:50:39 AM
if you had a stock 92 sidekick and wanted moderate upgrades (but street drivable) where would you start?
bumpers, roof top cargo rack, larger tires, winch, lights i don't want to start off stupid or have to go back and change a lot of work.
thanks, builder1
you really need to explain what you want the "moderate upgrades" to enable you to do.
For example, if you just want to explore logging roads and go camping, a roof rack might be all you'll need (and if there is only one passenger you might be able to do without that).
well lets see streetable decent 4x4 you could do 2"body lift,coil spacers,30x9.5 tires new rims from ford or dodge with decent back spacing so your tires wont rub on full lock that will give you about 5"-6" of lift from stock for under $1000 add a 5000-6000lb winch and bumper for the time you go out wheeling and say ...oops :laugh: priceless but that for a streetable 4x4 that will take you all most anywhere you will want to go thats fairly reasonable and what alot of people are running and it depends on how much $$$$ you want to spent but there are lots of up grades out there it the $$$ that it all depends on
