ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: faulknern on December 01, 2011, 02:19:03 PM
Title: No coolant circulation! Please help!
Post by: faulknern on December 01, 2011, 02:19:03 PM
Well guys I am stumped and I need to turn to you for some help.
Working on a 1997 Sidekick sport 1.8.
I can not get the water pump to circulate any coolant.  I have had the thermostat out, the rad disconnected to try pulling coolant from a bucket (after filling the block with coolant).
Rad flows freely, I can pour coolant in the top of the engine and it comes out the bottom so I don't believe there to be any blockages.
Thermostat is new.  Pump is new.
Funny thing is I get circulation through my heater core.
I don't understand.  Any insights?
Title: Re: No coolant circulation! Please help!
Post by: rascott on December 01, 2011, 02:36:21 PM
the pump is not the kind that will lift much water. sucking out of a bucket would not suck much and certainly not prime itself. i've never seen an impeller break off
it is overheating?
sounds like you have looked at the obvious.
Post by: faulknern on December 01, 2011, 02:46:38 PM
Thanks for the reply.
Yes it overheats.  The upper rad hose builds lots of steam pressure and the lower stays stone cold.
Post by: rascott on December 01, 2011, 03:25:26 PM
strange- seems a little backwards from a bad thermostat, and i see you've replaced that....and run without thermostat?
perhaps pressure test the system(i have my own tester, but some parts store may lend one)
i have seen radiators loose enough of that fin stuff to not loose enough heat, but that would slowly overheat.
Post by: rascott on December 01, 2011, 03:27:48 PM
i don't think the pump is bad- that would be way weird.
Post by: faulknern on December 01, 2011, 03:36:10 PM
I'm pretty sure the thermostat is operating correctly.
If I shut it down hot and disconnect the upper had hose and squeeze the lower hose fluid will come out the top.
Perhaps I should try run without it again.
Post by: faulknern on December 01, 2011, 04:48:32 PM
Boggling.
I removed the spring from the old thermostat and using this everything works.  Runs cold of course but circulates at least.
Why on earth would these two new thermostats not operate properly?  I know it's the right part number and for reverse flow...I looked it up myself.  I tested it in my kitchen...I know it opens.  I know it's hot down there, the return from my heater which was getting scalding hot dumps right on it.
I did read a thread on another forum saying that he would only use a suzuki thermostat.  Is there really that significant a difference?
Post by: ebattleon on December 01, 2011, 04:55:17 PM
Thermostats have various temp ratings are you sure your is right for you engine...and you cant go wrong with OEM.
You could also have a blown head gasket... :o
Post by: faulknern on December 01, 2011, 05:17:53 PM
Yes, positive the temperature is correct.
I sure hope it's not a head gasket...it runs beautifully otherwise and I don't see any other symptoms.
Post by: ebattleon on December 01, 2011, 05:31:19 PM
remove all the plugs and turn the engine by hand and take a look at the pistons if any look clean and shiny odds are you have a blown head gasket. Of course a compression test and leak down test are better ways to confirm... :-\
Post by: rascott on December 01, 2011, 06:14:56 PM
Boggling.
Post by: faulknern on December 01, 2011, 08:34:37 PM
Would running the thermostat open as I am now disguise a head gasket problem?
Post by: mrfuelish on December 01, 2011, 10:33:13 PM
check the rubber on the bottom pulley, the rubber will wear out and the pump will not spin fast enough, (I know after about 275.00 for a new one) from the harmonic balancer, and yes some times the blades on the new impeller will spin on the shafts also so the blades just sit there in the pump.
Post by: rascott on December 01, 2011, 10:55:42 PM
i don't think it would mask it for long.
also, the low operating temp. could screw with the engine control. on mine the computer adjusts stuff until the engine is warmed up- like a choke. much more efficient when it's "hot".
you probably should try another thermostat.
if it continues to overheat as you decribed, i think you probably are looking at a head gasket.
it's only time and money.
the comp/leak test and pressure tests could confirm, and sometimes compression gas can be seen coming out the radiator fill(running, cap off). fix it before coolant starts mixing with the oil. that's hard on the bearings.
Post by: faulknern on December 01, 2011, 11:10:36 PM
I agree, running cold is not a long term solution.  I just thought it might hide some symptoms when it is this way.
I guess I will try different brand of thermostat tomorrow and failing that do some head gasket testing.
I'm not sure what mrfuelish is referring to about rubber wearing down.  The pulley that drives the pump is just a metal pulley on this model.  Maybe on the 1.6 things are different.
Thanks again for all the guidance and help!  Will report back tomorrow.
Post by: fordem on December 02, 2011, 07:26:59 AM
He's referring to the crankshaft pulley - not the pump pulley.
The J series (and H series) Suzuki engines have one significant difference from the perhaps more conventional cooling systems (like the G series) - the thermostat is located 'downstream' from the radiator, in the cool return side of the loop AND THE COOLANT FLOWS THROUGH THE THERMOSTAT IN THE REVERSE DIRECTION.
It is important to recognize this for two reasons ...
 - the first reason is that the thermostat is not sitting in the water outlet elbow surrounded by hot coolant - it requires coolant to be circulating through the heater core and returning to the back of the thermostat to warm the wax pellet - if this flow is blocked the thermostat will not open - you can bypass the heater core with a loop of hose to check to see if a blocked heater core is the problem.
 - the second reason is that the wax pellet in the thermostat has to push the valve off of the seat IN THE OPPOSITE DIRECTION TO THE FLOW OF COOLANT.
Once you have verified that a blocked heater core is not the cause of your problem, I suggest you try an SGP thermostat (it should be available from SouthWest Suzuki motors)
Post by: ranger88den on December 02, 2011, 08:15:48 AM
I don't know about the 1.8, but when installing a thermostat in a 1.6, the thermostat bleed hole should be pointing to the front of the engine.  I've never done it differently so don't know what the results would be.
Post by: ranger88den on December 02, 2011, 08:20:26 AM
additional info:
http://www.kick-fix.com/buy-parts.html#STAT18 (http://www.kick-fix.com/buy-parts.html#STAT18)
Post by: faulknern on December 02, 2011, 02:52:06 PM
I believe it needs to be at 12 o'clock position on the 1.8.
Trying new thermostat here momentarily...
Post by: faulknern on December 02, 2011, 04:45:19 PM
I actually think towards the front of the engine would make more sense.  That would put the pellet closest to the return line.
Going to give that a try as I couldn't get a different brand thermostat until tomorrow.
Post by: fordem on December 02, 2011, 07:34:09 PM
I covered this a few posts earlier - if you put the wax pellet closest to the return line - where would it get the hot water it needs to open?  In this design, the thermostat is dependent on water flowing through the heater loop to warm it so that it opens.
Also -  if I remember correctly - there isn't enough room in the thermostat cover for the wax pellet - the thermostat can only fit one way.
Post by: faulknern on December 02, 2011, 07:58:50 PM
Sorry, perhaps my wording was not clear.  I was referring to the return line from the heater core, which is where the hot water comes from.
The thermostat is still inserted the correct way.  The opening is offset so I tried rotating it differently so the jiggle pin was to the front of the engine and the valve is closer to the back which is where the return line from the heater core comes in.
This did not help.  Waiting on another brand thermostat on monday.  Until then, she's running open loop with some cardboard on the rad.  It's maintaining temperature nicely like this so it will do for now...
Post by: rascott on December 02, 2011, 09:15:36 PM
this is sounding better. if the head gasket was leaking, i don't think you'd be able to run it long before it would start puking.
i'm interested in what happens with the new thermostat....
Post by: fordem on December 03, 2011, 10:04:22 AM
Ok - I get you now - the jiggle pin needs to be at the top - it's purpose is to allow trapped air to bleed.
