ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: jerryp58 on May 04, 2004, 10:30:43 PM
It looks like I lost this original thread during last night's Forum problem. Sorry if the original is still out there or shows up again.
Anyway, I am removing my mechanical fan and putting in an electric fan. I pulled the mechanical fan the other day to test fit things and I was thinking I'd like to replace those long water pump pulley bolts with shorter ones, but, I couldn't see how they could be removed.
Can the water pump pulley bolts be removed? Or are they attached to the water pump itself?
I used 10 pennies drilled them out and they made awesome washhers when in a bind! i did the same thing and the bolts hit so i reached in my pocket and pulled out some change!Best 10cents iv'e ever spent
I would replace the studs.
They're studs! I never would have thought of that. Thanks I'll give it a shot.
LOL, you haven't changed your waterpump
yet have you. When you get a new pump,
it won't have studs in it either, at least all
the pumps I've changed didn't
I like Stainless Steel hardware, so I used
Allen head SS bolts, they look really nice,
and give a clean appearance.
i just put on my 13" 'S' el. fan tonight. i left the studs on for now, will be replacing soon, fit was tight so i 'leaned' the radiator forward about 1.5", plenty of room now. the 13" fit good with almost no room top to bottom. plenty of room left to right so i put it about where the mech fan was and cut the shroud and kept the driverside attached to help direct the air to the fan better. started it up, the fan kicked on a lil bit after the thermistat opened and ran all the time. the heater gauge never got past 1/2 but seems hotter that before by about 1/8 to 1/4. the thing i didnt like was that the fan kept running 10 min after i shut the motor off.... shouldnt be to bad on the battery :-/ have a small fuel leak so i only drove it 2 miles, dont know how it will be on the road, or mud.
o, and the mounting hardware is lame, i just slowly pushed the plastic screws through, worked and nothing is leaking. wasted $5 on extra hardware :P
good luck with yours, would like to know if you can tell a difference in proformance. ???
I didn't like the 16" electric fan I bought,
it just couldn't keep the engine cool enough
with the turbo and the intercooler, might be
OK with your setup tho
Hmmm... between your and Wild's post about running warm, I'm a little worried. I was expecting an electric fan would be fine on mine because at one time I had a 160* thermostat in it and it didn't go above 160*. Now I have a 180* in it and it stays at 180* (I'm assuming the actual number based on where the gauge was with my original 190* thermostat). Anyway, it seems like overheating wasn't a problem with the little clutch fan (even with the shroud off now it hasn't changed), so I figured that an electric would be able to keep up. Guell I'll find out :-/
I'm wiring mine with a relay that will be switched on/off through a switch on the dash that is run off of the ignition. So, when the ignition is off, my fans shouldn't get any power, plus I can turn them off manually if I like. Hopefully that's the way it'll work.
I hope to get the fan on this weekend. Mounting is tight. I was thinking about using the original shroud, but I think I'd like to keep the original parts intact, so I guess I'll try to figure out some kind of bracket. I'm a little leary about using the "zip ties" -- the fan I have is kind of heavy.
Mine would run hot whenever I put it in low range. So when I put the tranny cooler on I also put a pusher fan on the outside. I used a fan off a newer sport model with a/c. I also left the mechanical fan on for extra help. I have to have the pusher on whenever I'm wheeling... even in the snow.
Brian
i dont know what my actual temp is. but after driving my G/Fs 93 today, i see that i am only over her temp by 1/8 on the gague. mine sitting, hers on the highway...
i hated cuting the shroud, what ya ganna do :D
and i didnt like the zips either but the fan is light. i pulled my a/c a few yrs ago and still have the push fan and i might install it to work with the new on. my new one didnt have an option to hook into the ignition :-[ wish it did, might add a cut off switch.
I did the opposite, I installed a fan over ride
so I could turn it on when sitting on the trail,
instead of waiting for the engine to get to 180*
which is where the little thermostat turns the fan
on at.
I drilled a small hole and tapped it so I could screw the
thermostat right onto the intake manifold right where the
coolant thermostat lives, I did'nt go into the water jacket,
just on the little tab thing that sticks out by the neck where
the top hose connects.
I took the harpoon thing off the Thermostat sensor that you
are supposed to stick through the Radiator (cheesy) and put
it on the engine so I get cooling as soon as the engine gets
to 180* not the radiator to 180*
Here is a Pic to help with the visualization
(http://wildcatent.freeyellow.com/manifold.jpg)
Sorry the pic isn't closer, this is just one I had on file.
good idea, my fan temp sensor wont do that i dont think, i did lower my fan temp so it kicks on right when the therm opens. if you ever get around to getting a better pic i would sure like to see it.
OK, I'll go out and snap one.
be up in an hour or so
on at.
That's definitely a much better set-up. I look forward to the detailed pics.
I pulled my clutch fan tonight. Drove it around for a bit and it stayed cool (about 85* ambient this afternoon) even idling at traffic lights. These things must have really efficient cooling systems on them.
I hope to get the electric installed tomorrow. We'll see, I'm a mighty slow worker the older I get ::)
Well I got all the dirty pictures :o
LOL
(http://wildcatent.freeyellow.com/fan-stat1.jpg)
And Another angle for a better look
(http://wildcatent.freeyellow.com/fan-stat2.jpg)
I'm not using the Electric fan now, it just can't pull
enough air to keep the whole works cool
Well, got the electric fan in today. It's wired with a probe thermostat and a separate cut-off switch. The fan seems pretty powerful. It's an eBay purchase off of a Daewoo car supposedly. I think it'll work out fine. Mounting was a little weird, but I think I have it secure. I guess time will tell.
I pulled one of the water pump pulley studs and took it to the local Home Depot but wasn't able to find a matching bolt. The size looked to be M6-1 (whatever that means). HD doesn't seem to carry a lot of metric. I think it's gonna take some searching to find replacements. At least they're not in the way.
After I've lived with the fan for while, I guess I'll post my feelings about it.
Thanks to all for the help.
well i put about 8 miles on mine tonight breaking in the pistons seals, which is a lil stressfull, temp only got a lil over 1/3 on guage ;D, but the temp outside is under 70 and it was raining a bit but im hopeful.
nic pics, thanks. mine is ALOT different.
i can garantee you that HD, manards and lowes will not have what your looking for, i have looked. need to goto a auto parts store or an industrial supply store, LOTS of bolts ;)
good luck and please keep posted on how this works out and i will do the same 8)
My local Ace Harware has a real kickass
hardware selection, even Metrics, I just
used some short 10 or 15 mm bolts
m6-1 means 6mm 1 thread per mm
8-1.25 is 8mm 1.25 threads per mm
and so forth, more threads per mm
is a fine thread, less is a coarse thread
hope this helps
