ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: segermech on December 14, 2011, 05:48:59 AM
Title: Hi Compression Pistons
Post by: segermech on December 14, 2011, 05:48:59 AM
Anybody ever use the HC Flattops on a Sammy 1.3 EFI.  The EFI version of the motor is a G13BA.  The pistons are already flattop.  Are the Hi compression pistons only used on the carb version?
I have to replace the pistons anyway (long story) any thoughts on brand normal compression HC I'm thinking 20 over.
If the Hi compression pistons work will I need to run Hi Octane?
Title: Re: Hi Compression Pistons
Post by: fordguy79 on December 14, 2011, 08:22:25 AM
Get it touch with this guy his name zack http://zukiengines.com/ (http://zukiengines.com/) he can give you the run down on a good set up for you
