ZUKIWORLD Model Specific Suzuki Forum => Suzuki Sidekick, Vitara, Geo Tracker (Gen. 1 Platform) 1989-1998 => Topic started by: hwyman on December 17, 2011, 02:40:46 PM
I am going to attempt to make my own brush guard since I can not find one anywhere for my 94 2 door tracker. The one area that I am having trouble is how/where to bolt it up to. Does anyone have one that will take pics of how thiers is mounted so I have some idea how to procede?
Travis
My brush guard is from a Isuzu Rodeo, just cut down a few inches in order to fit the grill properly. For mounting I welded some tabs to the frame to bolt onto, then drilled a couple of holes through the bumper. I'll try and get some pictures for you.
I'm interested in seeing some pictures too :-)
Cut down this Go Rhino brush guard (I found on Craigslist) 6 inches in height, then fabbed some mounting brackets from 1/4" plate (a bit over kill). Been mounted now for almost two years... and it has never loosened or moved from where I mounted it.
http://www.zukiworld.com/forum/suzuki-grand-vitara-vitara-chevy-tracker-(gen-2-platform)-1999-2005/grille-guard-needed-for-03-tracker/ (http://www.zukiworld.com/forum/suzuki-grand-vitara-vitara-chevy-tracker-(gen-2-platform)-1999-2005/grille-guard-needed-for-03-tracker/)
I forgot to take pics of the brush guard, I will today.
But I will explain the best that I can how it mounts, very simple actually. It uses the stock bumper mounting bolts. The thick mounting plate steel has a 90 degree bend towards the centerline on the forwards edge. it has 1 hole in the front and there is a threaded insert in the end of the brushguard and a single bolt per side holds the pushbar in place. It isnt the strongest setup, it isnt intended as a pushbar as it is rather thin steel.
[url]http://www.zukiworld.com/forum/suzuki-grand-vitara-vitara-chevy-tracker-(gen-2-platform)-1999-2005/grille-guard-needed-for-03-tracker/[/url] ([url]http://www.zukiworld.com/forum/suzuki-grand-vitara-vitara-chevy-tracker-(gen-2-platform)-1999-2005/grille-guard-needed-for-03-tracker/[/url])
Nice job. That looks very similar to the one on Drone637's Tracker.
Thank you, Brd Hntr. It has been surprisingly sturdy. I have actually pushed vehicles with it. I coated it with Herculiner after I cleaned it up just using the Herculiner fluid and not stirring the rubber particles into it. Then after it air dried I spray painted it with a couple coats of semi-gloss rattle can Rustoleum to protect the Herculiner coating from sunlight.
