ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: mbruce on December 19, 2011, 06:57:57 PM
Title: Toy Axles/YJ 35" tires???
Post by: mbruce on December 19, 2011, 06:57:57 PM
Anyone running 35" tires with the YJ springs on Toy axles under a Samurai? Did any modification(s) need to be done so the 35" tire could still do its thing without rubbing?
Title: Re: Toy Axles/YJ 35" tires???
Post by: moonzuk52 on December 27, 2011, 10:53:46 PM
no but i stock sammi with 4140 front  axles and stock rears with 5.12s. tires are 37 12.5 on my sammie. with 8.1 tcase gears. all stock. beside coils front and rear.
Post by: Jordan on December 31, 2011, 02:28:51 PM
I am in the middle of a Toyota axle swap on my 82 sj410, I'm just running 33" tires but I think you would have room for 35's with the yota diffs and a yj spring over axle setup, if not you could trim the fenders a bit or just get 2" lifted yj springs and that should give you lots of room for 35's if you don't want to trim the fenders.
