ZUKIWORLD Model Specific Suzuki Forum => Suzuki Sidekick, Vitara, Geo Tracker (Gen. 1 Platform) 1989-1998 => Topic started by: thomastuning on December 25, 2011, 03:06:09 AM
well cutting was easy :)
hope it will come out later when finish
the gas tank will be placed where it seats on the photo
any suggestions will be welcome tnx
i also put the 3'' inc lift now i have to find out how to make the gears working and the low gears to
first third and fifth gear ok but on others :)
i will make everything since i am trying to keep the cost as low as possible here's two photos of the shiffter
poor english but i am trying :)
Make sure you create a firewall to put between the rear seats and the gas tank. Are you going to install a cage so the gas tank has some protection?
yes iam going to put a roll cage but with bo rear seat seat on
2 seats in the front 1 bucket for the driver
i need help with tge gear shifters any suggestions or links?
On mine the gear lever was cut at the bottom and a 3" extension welded in, others have simply bent the lever to clear the hole in the floor.
