ZUKIWORLD Model Specific Suzuki Forum => Suzuki Samurai (All SJ Platform) 1981-1998 => Topic started by: bigbasshb on February 02, 2012, 09:29:24 AM
Title: Advice needed for 88 sami project
Post by: bigbasshb on February 02, 2012, 09:29:24 AM
Hey there guys & gals.
I know you have been asked some of these questions before & I'm sorry for making you go through it again. I just get a little confused since I have seen a couple of differing answers to some of these question.
I have a 88 samurai (round vents) that I am going to be fixing up when I get my taxes back. It is completely stock & a rust bucket, but the entire drivetrain is awesome. I want to do mild wheeling & be a daily driver mostly around town maybe an occasional trip on highways with 50mph limit.
(http://i206.photobucket.com/albums/bb241/bigbasshb/88samurai.jpg)
Its going to get a lift & I think I have settled on a spoa conversion. I have seen quite a few of them & they all seem to have different features. I want as complete of a kit as I can buy. My question is... What kit from what manufacturer do you guys/gals run on yours?
I also have a set of rims & tires that I took from my retired ford f-150 that I want to use. They are the factory aluminum outlaw style & have the proper bolt pattern. The center hole is to small to see if they will fit but the plan is to have the center hole enlarged. The tires that will be used are the Firestone wilderness 31-10.5-15. Has anyone used these rims on a samurai? I want to measure the rims before I have the work done to enlarge the centers. Anyone know what I'm looking at for measurements?
The sami is also going to need a new clutch. Any ideas on what I should go with (stock, aftermarket, or ceramic)? How will it hold up to 31 inch tires? Will gearing correction help with clutch lifespan?
As I stated above... Its a rust bucket, but I'll be doing all of the body work myself. I'm also going to be putting fender flares on it, but since all of the fender flare brackets are either missing or rusted to death I'll need flares that won't need them or that have mounts that I can bolt on. Any ideas on flares? Does anyone have a source for tailgate hinges?
Last but not least... My speedo doesn't work & I assume that its the cable & will be replacing it. I'd also like to change it for a cluster with a tach. Anyone have any sources?
Thank you for reading my many questions & thank you in advance for any & all answers.
Title: Re: Advice needed for 88 sami project
Post by: Drone637 on February 02, 2012, 01:21:20 PM
For the tach, I would give Hawk Suzuki a call.  Make sure you get the same year, if you do it should just be a straight cluster swap.
For a purchased SPOA kit I recommend the Stage 2 from Sky Manufacturing.  It has the best set of spring pads you can get for the conversion and includes brake lines, spacers and Cross-Over Steering kit.  Everything you need to get going safely.
http://www.sky-manufacturing.com/new/detaproduct.php?id=92 (http://www.sky-manufacturing.com/new/detaproduct.php?id=92)
For the clutch, I just use stock ones.  Cheap and easy to get, and your right that proper gearing will help.  You can either get a t-case kit, which I recommend, or go with axle gearing.  There are arguments both ways but I think a 4.8:1 t-case kit is just about perfect.
You can play with gearing and see how the tires will effect things with a gearing calculator.  I use http://www.solemnwarning.net/transmission/ (http://www.solemnwarning.net/transmission/) since it has most of the SJ gear boxes and aftermarket transfer case gears built in.  Makes it easy to generate up different gear sets.  :)
Post by: Capt on February 02, 2012, 02:45:23 PM
Drone has you headed the right way,
I have a 4.9 trans case gear kit from LowRangeOffRoad.
Also I have the Petroworks Clutch, Ceramic/Copper on one face, Carbon Combo on the other, and so far its been great.
I went thru 2 stock clutches (One was a bad pressure plate), but that was before the Transfer case upgrade.
You will really see the difference the 4.9 case does. I'm running 31x10.50x15's and got 5th gear back.
and have no problems "Trail Driving" anywhere.
CAPT
Post by: 02CalTaco on February 02, 2012, 08:08:58 PM
For the gauge cluster with tach I would keep my eyes out for one on Craigslist, eBay or on the forums. Expect to pay from $40-75 from one of those sources. I'm not sure what hawk charges for them but Im amazed at what some samurai salvage places charge for used parts, sometimes as much or more then new from the dealer.
Post by: bigbasshb on February 02, 2012, 09:37:10 PM
Thanks for all the info. You guys are great. I'll be going with the stage 2 lift with shock mounts. The lift doesn't mention u-bolts. What have you guys been doing for u-bolts? I have a spring shop that will make them for like $80 a piece but it seems a bit high. The 4.9 case gears look like a good option.
Any ideas on the other questions? Tailgate hinges? Fender flare options? The ford rims I mentioned?
|removethispart|@Capt how much was your clutch?
Thanks again.
Post by: Skyhiranger on February 03, 2012, 06:38:57 AM
You can buy ubolts from various auto parts stores.   For all 8 of them, it should be less than $80.
As long as your F150 wheels are 5 bolt and off a 96 or older, it should have a 5 on 5.5" bolt pattern (which is the same as the samurai).  For the center hole diameter, it has to be big enough to fit over the lockout hubs (be sure to measure the hub where it bolts to the wheel hub, that is where the lockout hub is the largest).  Generally, 4 1/8" to 4 1/4" is the range that the holes are enlarged to.
You can post a "wanted" ad in the classifieds section on here, looking for tailgate hinges.  Or you can check with some of the various suzuki vendors that part out samurais.  You might even still be able to buy them new, from the dealer, if you want to go that route.
The tach cluster you need will come from an 86-88 samurai with the round vents in the dash.  You can also just add an aftermarket tach, if you want.
Lower gearing would be good.  Either in the axles, tcase, or both.  If you go with lower gearing, you should be able to just run a stock clutch and it should hold up fine.
For flare options, that may be difficult, if you don't have anything to attach them to.  You could try sticking them on, with some super strong adhesive.  That may work better than trying to screw/bolt a flare or bracket onto really rusty metal.  If the underside of the wheel wells are still in relatively good shape, you could get some rubber flares that just screw onto the underside of the wheel wells.
Post by: Drone637 on February 03, 2012, 08:57:52 AM
Originally for the U-Bolts I just flipped the spring pads over and ran stock shocks.  When I finally broke those I used u-bolts from a Jeep CJ and just drilled out the stock pads to accept the larger bolt.  Works great.
Post by: Capt on February 03, 2012, 03:20:45 PM
I had to dig back into my service file;
I bought the Clutch & Pressure Plate for $225.00,
Plus a new Pilot Bearing, Throw Out Bearing, And a New Alignment Tool.
The fee to the UPS man, Grand Total...$292.40.
And a tip; It's just as easy to pull the entire engine & tranny together, out the engine compartment, swap the clutch while it's hanging on the shop cherry picker, than to try to twist, yank, scarf your knuckles up, remove under body cross brkt, etc.........
CAPT
Pix are my retired rusty iron buddy, helping pull  clutch (actually his wife sends him over to save a AXE MURDER at their house)
Post by: Boxcar on February 03, 2012, 05:20:28 PM
I've got the tach cluster . $50
(http://i1109.photobucket.com/albums/h423/Boxcar2/001-1.jpg)
 As to the lift, Sky's stage 2 is a great kit .
 Don't forget to add the rear track bar . You will need it.
 I like the Spydertrax kit the best. Its simple, inexpensive, and it works well.
Look into re gearing the "T"case . Unless you hate 5th gear.
And shock relocate brackets. Or just pull the trigger on the Sky long travel kit. Money well spent...
Bushwhacker flairs are (IMO) the best bolt on flairs that don't require the origanal flanges.
 Now to the clutch. With 31's It kind of depends on your driving style .
If your allways going to be nice to it, stock will work.
I'm never nice to mine so I run a stage 2 Centerforce. Not only on my Zuke but on both of my Heaps (401 stokers) Never had an issue....
Have some fun ....Boxcar...
Post by: bigbasshb on February 03, 2012, 09:27:20 PM
You guys are awesome. I really do appreciate all of your help.
The info on the rims I'm looking for is the measurments for backspacing (measuring from hub surface to bead surface). Whats the min/max I can use with the 31s & what is ideal?
Quote from: Capt
CAPT
Thank you Capt. I looked into that clutch & it looks just like what I'll need. As for the removal... I'll be removing the front clip to do some firewall repairs so that was the plan.
Quote from: Boxcar
Man that cluster looks nice. How much with shipping to Richmond, MA 01254? I'll look into the bushwackers, I like their pocket style flares but they seem a bit wide. Rear track bar? Its the first time I've heard that I'd need one. The axel wrap is that bad with a SPOA conversion?
Do you have a favorite kit for the track bar?
Thanks again for all of the help you guys are giving me.
EDIT: I've been reading about the benefits of re-gearing the diffs rather than going all transfer case. What do you think about doing all the gearing on the diffs? What ratio should I go if I do that?
Post by: Boxcar on February 05, 2012, 02:57:22 PM
Yea, as I mentioned in my earlier post...The Spydertrax kit. It's my pick. And on my rig.
Axle rap is allways a problem on any SPOA lift.
 I,m at 97103 . Pick your favorite shipping company and get a quote. Shouldn't be much. Will fit in a shoe box. Probably 3 or 4 pounds.
Post by: Boxcar on February 05, 2012, 03:01:49 PM
Re gearing the diffs can be cheaper.
Mine has both  and I did them at the same time, so I really don't have a good frame of reference for you.
 I do know that I did the 5/12 ring and pinion for both axles at around $250 .
The transfercase gears were around $600...Boxcar...
(http://i1109.photobucket.com/albums/h423/Boxcar2/002-1.jpg)
Post by: bigbasshb on February 05, 2012, 08:42:31 PM
So I went ahead & ordered the sky stage 5 since it came with the shocks & mounts. I ordered it here for $100 cheaper than the sky site. http://www.roadlessgear.com/page/RGL/PROD/SU/SPOA-005 (http://www.roadlessgear.com/page/RGL/PROD/SU/SPOA-005)
I also ordered the track bar here since its a full bolt on http://www.sky-manufacturing.com/new/detaproduct.php?id=95 (http://www.sky-manufacturing.com/new/detaproduct.php?id=95)
I haven't ordered the gears yet because I'm still up in the air about what to do. I have read that if I do all of my gearing in the diffs it will take the strain off of all of the rest of the drivetrain. I really don't care if its cheaper to go with just diffs, what I'm really concerned with is longevity of the parts I put in as well as the parts I don't. The best I could come up with for diff gears was the 5.38:1 gears & that was still gonna put me at 4k on the tach at 60mph so all diff isn't gonna be an option.
Boxcar I definitely want that cluster. USPS for 5 lbs priority mail is just under $12 for USPS-Produced Box: 13-5/8" x 11-7/8" x 3-3/8" or 11" x 8-1/2" x 5-1/2", but I'd send you $20 just to be safe. How would you like the funds? PM me your info so I can get these funds to you.
My rims are a similar style as yours.
(http://i206.photobucket.com/albums/bb241/bigbasshb/DSCF0853.jpg)
What is your backspacing & tire size & did you use spacers? BTW great job on your sami it looks awesome. Did you build the cage yourself?
Post by: Drone637 on February 06, 2012, 08:52:11 AM
The issue with going with diff gears only is you don't get the low range reduction along with it.  If your only doing dirt roads it isn't an issue, but for proper trails at least a 4:1 is required.
Post by: bigbasshb on February 06, 2012, 08:13:08 PM
Thank you Drone637. I've decided to go with the transfer case reduction of 4.9:1 http://www.lowrangeoffroad.com/index.php/suzuki/samurai/transfer-case/4-9-1-tcase-gears.html (http://www.lowrangeoffroad.com/index.php/suzuki/samurai/transfer-case/4-9-1-tcase-gears.html) & will play with it from there. I'll definitely be adding diff gears later.
Post by: Boxcar on February 07, 2012, 07:04:12 AM
3" back spacing on the wheels. The tire size on the shoes in the picture are 33x12.50 s (my tar baby's) I run 32x11.50 s on 2" back Mojocks  when wheeling it. I'm not a fan of spacers. I've seen to many disasters caused by them.
 Yes  I built the exo. It's 125 dom with 1.75 grinders mated to heavily modified Calmini tube bumpers.
 Thanks for the kind words...Boxcar...
BEFORE
(http://i1109.photobucket.com/albums/h423/Boxcar2/1115111850.jpg)
AFTER
(http://i1109.photobucket.com/albums/h423/Boxcar2/001-3.jpg)
Post by: tuxblacray on February 10, 2012, 07:37:07 PM
I think the other guys have ya headed in the rite direction so there is no need for additional comment about lifts...
You can take those Ford rims to a machine shop and have the centers bored out to 4.25 and they will fit over the lockouts. I have a set that I did on a Bridgeport Mill in the shop for my Vitara.
They fit on the Sammi but the backspace is every so close to the calipers without wheel spacers. If you run much mud you should expect to have it packed around the Calipers.
Does this spare rim look familiar? LOL...
(http://inlinethumb50.webshots.com/49137/2540260810081905758S600x600Q85.jpg)
Post by: bigbasshb on February 10, 2012, 07:51:51 PM
Thanks tuxblacray. That is awesome news. I figured I couldn't be the first to try to fit those rims to a sami. I have talked to the shop near me & they figure they could do it for less than $100 for all 4. I think I'm gonna look for a 5th as a spare too. Bet that cost me more than $100.
Boxcar... The check is in the mail. You should see it soon.
Post by: Boxcar on February 13, 2012, 05:13:06 PM
Nice Zuke Tuxblacray....Boxcar...
Post by: tuxblacray on February 14, 2012, 09:40:19 AM
It's gettin there Boxcar... Old Guyz gotta have a project... This winter No Corvette.... Sammi instead... LOL...
bigbassb....
$100 is pretty good. We charge $70 per hour for labor rate. It takes over an hour to run these by the time you set the mill up, lug the tire / rim around, get them up on the mill to run...
        Tux...
(http://inlinethumb14.webshots.com/45261/2460876230081905758S600x600Q85.jpg)
Post by: bigbasshb on February 14, 2012, 12:05:00 PM
bigbassb....
        Tux...
I'm gonna have to double check with them caz it sounded a bit low to me. They did request that I have the tires removed before bringing them in.
Post by: tuxblacray on February 14, 2012, 02:13:35 PM
Unless they have a really small mill they should be able to center them up and chuck them down without any problems. I did 4 of them with 235/75/15 and 1 with a 31/10.5 /15 on them with no problem at all on a Bridgeport Mill....
Lower the table down... throw the wheel up... center.... indicate it in.... lock it down... mill.... pretty simple
                                                  Tux...
Post by: bigbasshb on February 22, 2012, 08:34:04 PM
Boxcar you are awesome. The cluster came today & has already been installed. It works great.
(http://forum.softwareworld.me/public/style_emoticons/default/thanks.gif)
BTW I was glad to see you in that other forum. Those people need someone like you to answer their questions.
Post by: Boxcar on February 22, 2012, 08:53:23 PM
Yea. They hate me allready....Bunch of knuckle heads....
 Glad you like the cluster.
Keep posting your progress. It's gonna be a great Zuke............Boxcar.......
Post by: bigbasshb on February 25, 2012, 09:25:48 PM
Hey Tuxblacray,
I don't know how much you check into that other forum so I duped my post over here. You guys are great here. A big (http://forum.softwareworld.me/public/style_emoticons/default/thanks.gif) for all of your help. You don't realize how rare it is to get good answers rapidly from other forum based places like this.
As an admin of a software forum myself, I didn't want to say the name of this forum as that isn't really fair. What I did want was for their other members to know that there are other places to get help & advice.  Maybe they'll search & find this place.
BTW: All of my parts are in now & I'll be beginning my build next week. As for the rims I decided to do them myself (without a mill). How you might ask... I went old school with my router & 2 flush trim bits. 1 with bearing on top & the other with a smaller bearing on the bottom. The first rim is done & it came out great.
Post by: tuxblacray on February 28, 2012, 12:48:43 PM
I don't spend much time there. Mostly because alot of the folks are outside of the USA. Nothing against that but it makes some things more difficult. Parts to them, from them as an example. Likewise only a few folks would respond.
As you probally saw I don't have a problem in telling folks about Zukiworld, Zuwarrie, ZukiKrawlers.... In no way am I saying I don't like it here... My windshield banner says otherwise! But, when it comes down to finding information about Zuks, or parts, or events then its and all for one deal. Helping each other get the answers they need is the right attitude.
At any rate I am pleased to see your build is in progress! If there is anyway I can help just post up or send me a PM.... I'll be around as long as I'm above ground....  ;)
Post by: Boxcar on February 28, 2012, 07:13:42 PM
What he sed ...Boxcar...
Post by: 87Suzi on March 06, 2012, 08:02:33 PM
Could you PM with details and a picture of how you did this? I have access to a router but not a mill and every place with a mill won't touch rims for some reason.
Post by: bigbasshb on March 08, 2012, 03:05:12 AM
I'll make a post about how I did this with a router as soon as I get some time & my camera connected to my pc. But if you look on the home depot site & search for router bits you can find the bits I used. They are both flush trim bits & 3/4 inch 1 with bearing at the top & 1 at the bottom. If you look at the bits you may be able to see how it was done.
Post by: bigbasshb on July 19, 2012, 06:27:15 PM
Hey Guys/Gals,
My swisszuki is progressing very nicely. I had a long break from it due to an injury but am back on track now. Will post picks of the build when I'm done.
I do need some more advice from you knowledgeable folks.
As you know I am running the Sky stage 5 SPOA kit with OTT steering. I have run into a small problem with the sway bar & steering link hitting each other while turning to the left. I think I want to keep my sway bar since it will be mostly a daily driver. Does anyone make extensions for the sway bar? Do any of you run your sway bar with the SPOA lift? What did you do to make it work?
As always... Any & all info provided is greatly appreciated.
Post by: tuxblacray on July 28, 2012, 03:30:04 AM
Hi Bob... Sounds like your doing real well with the Zuk. I am not SPOA so I can't answer your lift question from experience. If it were me though and the sway bar gave me a problem I would remove it. If it didn't drive well on the road then I would install a Panhard Bar which does essentially the same thing.
Post by: bigbasshb on July 29, 2012, 08:30:39 AM
Thanks for the reply Tuxblacray. I ended up making my own extensions using some 1" square stock I had laying around.
