ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: bigmuddin87 on March 01, 2012, 05:08:37 PM
Title: running high at idle.
Post by: bigmuddin87 on March 01, 2012, 05:08:37 PM
i got help to set timing and now the when starts it running high idle. it setting at 2000 rpms. could it be distributor or something else??
Title: Re: running high at idle.
Post by: LowRangeWilliam on March 01, 2012, 08:16:18 PM
check your vacuum hoses did you have distributor out? timing belt off? what did you do other than set timing?
Post by: bigmuddin87 on March 02, 2012, 03:43:57 PM
i check all vacuum hoses are hooked up. cam 12 crank 12 and distributor at no. 4 tower. i reset idle screw. i got down at 1000 rpm.  runs great now.
