ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: rockybaroofy on March 06, 2012, 04:44:26 PM
does anyone know what the gear ratio's are for the 5spd. in a 89-98 4cyl. tracker ? doing a bit of research for possible gear swaps . any info would help
Don't search much, do you? :P
http://www.zukiworld.com/forum/general-suzuki-forum/tranny-gear-ratios/ (http://www.zukiworld.com/forum/general-suzuki-forum/tranny-gear-ratios/)
The only thing to add to that is the other 5th gear ratio. 5 speeds that came behind 8V engines had a .86 ratio. The ratio was .795, for ones that came behind 16Vs.
