ZUKIWORLD Model Specific Suzuki Forum => Suzuki Samurai (All SJ Platform) 1981-1998 => Topic started by: h82lose on March 13, 2012, 10:19:25 PM
Hi all,
First samurai , or any other 4x4 project. Just looking for some input. I just picked up 2 samurais ...1= 88, 1= 90. Neither has a working motor. The " package "did include a 1.6 16v taken apart accept for the pistons/crank, which i am taking to the local machine shop this weekend. the 88 has a stock 1.3 (locked up, it was in a flood) Body is very nice on 88 .... 90 has potential . My questions..... I know where I can get a set of toyota axles with rro yj conversion hi steer and a set of beadlock wheels for $1400, or should I look for a set of cj5 axles? My plan is to build the 88 to be my dd , along with some moderate offroad. Then, as time and $ permit, turn the 90 into my trail rig. With that in mind I was planning to put the 1.6 in my driver, probably 32/33 " tires, was considering 4.9:1 or 6.5:1 transfer case....... You guys can fire away any suggestions ......
Send a message to mbruce, he has been doing a Toyota YJ conversion recently and has some fun stories to tell. :)
what about gearing ? Also, I have been kicking around the idea of herculiner or similar on the outside........ any input ? :-\
Ok ...... so I start tearing into this motor that I was told is out of 97 tracker ...... but it's a 1.6 8v , it is my understanding that 97 tracker only had dohc 16v ??? Has 2CNBJ1863U6918016 stamped on block , any1 know how to find out what year , model this came from ? Also , I got in a hurry and and managed to mix up the connecting rods and caps :-X, am I gonna have to replace connecting rods now >:( ?
If it is an 8v it should be from a 89-94 unless someone did an engine swap. Are you sure you entered the VIN number correctly, this is what I get when I run it through a decoder:
Description Position Raw Data Decoded Data
Region: 1 2 North America
Country: 1-2 2C Canada
Manufacturer: 2-3 CN Geo
Model Specific: 4-8 BJ186 Unknown
Check Digit: 9 3 Invalid
Year: 10 U Unknown
Assembly Plant: 11 6 6
Serial Number: 12-17 918016 918016
