ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Bobzooki on April 13, 2004, 06:54:22 AM
Title: Technical Q:  Drilling BIG holes in Steel
Post by: Bobzooki on April 13, 2004, 06:54:22 AM
Alright all you geniuses.
I've got Calmini Belly Armor on the Gnewt.  I have to remove it to change the oil, and other fluids.  I want to drill holes in it so I DON'T have to remove it to change the fluids.  I don't have a torch, or a grinder.
What's the easiest way to punch some big holes in that steel, say 1.5 to 2 inches in diameter, so I don't have to drop the armor?  This is 3/16" plate steel.
Title: Re: Technical Q:  Drilling BIG holes in Steel
Post by: wildgoody on April 13, 2004, 07:09:40 AM
I got carbide tipped hole saws, but a Greenlee
hole punch is the cleanest way, if it can do that
thick of plate. The Greenlee is used by Electricians
to punch holes in electric service boxes to add
conduits, if you have an Electrician friend, you
might be able to borrow or have them help you
punch holes.
Post by: Bobzooki on April 13, 2004, 07:11:40 AM
Yeah, I know about greenlee punches, but didn't know if they could handle 3/16" steel.
Post by: wildgoody on April 13, 2004, 07:16:47 AM
I know a shop here in town that has a
punch machine that can do holes in up
to 1/2" plate, it's really cool to watch,
perfect holes just look sooooo good.
Post by: Zukipilot on April 13, 2004, 07:24:28 AM
Mark your locations, pull it off and take it by a local machine shop. Something that simple for them should be cheap enough.
Post by: Speedracer7c on April 13, 2004, 07:49:16 AM
I was going to just do it with my air cutting tool and make the hole square....
Post by: rockrat on April 13, 2004, 08:28:06 AM
mark it and use a hole saw if you want to do it cheaply. a good hole saw and 1/2" drill will handle 3/16" with little effort
Post by: Bobzooki on April 13, 2004, 08:35:15 AM
When you say "good hole saw", what is it made of, and where do I get it?  Is it a special material to cut steel?
Post by: Whipp on April 13, 2004, 09:42:11 AM
With the high location of the trackick's oil plug - and the protection provided by the skid plates, I've been considering getting a fumoto valve (http://www.fumotovalve.com).  It would at least ease oil changes.
PS:  Bobzooki - I'm the guy who went on the snow run with you in the beginning of March.  I'm looking forward towards some more trips up in the hills.
Post by: Bobzooki on April 13, 2004, 09:49:09 AM
Craig?  Is that you?  Man this is going to be one hard-wheeling summer!  I have a zillion runs I want to do, including one over Medano Pass, into the back side of the Sand Dunes.
Post by: Whipp on April 13, 2004, 09:57:26 AM
Craig?  Is that you?
Yep, it's me!  I'm not sure how much wheeling I'll be able to do, but hopefully a few weekend trips.  And at least one week long trip around Gunnison - I'll be the "chuck wagon" for rest of the people on the trip.
- Craig
Post by: rockrat on April 16, 2004, 11:00:45 AM
I have used the steel cutting hole saws made by dewalt on a 1/2" drill and cut (7-8) 1.75 holes through 3/16" before any sign's of wear
Post by: Charlie on April 16, 2004, 01:32:47 PM
You could scribe a circle then drill all arrond the outside with a small drill, knock out the centre with a cold chisel and then file it smooth.Not the easiest way to do things but it's the cheapest.
Regards Charlie
Post by: Bobzooki on April 18, 2004, 01:02:44 AM
Hah, so I got the 2" bi-metal hole saw (BluMole) at Home Depot - damned thing lost its teeth before I was half way through.  I drilled small holes around it, and it still wouldn't finish the cut, so I finally put a metal blade in my saber saw and finished the cut.  What a pain in the ass.
Post by: NY_SIDEKICKER on April 18, 2004, 03:49:13 AM
YEA BUT CHANGING THE FLUIDS WONT BE ANY MORE  ;D
Post by: 87BlackSami on April 18, 2004, 02:04:25 PM
ZEP Products Co makes Drill Chill for boring holes in metals. Get something like that next time and turn the hole saw in the drill slow to save the teeth.
Post by: Wildweasel on April 18, 2004, 09:28:51 PM
When using a bi-metal hole saw for steel, you should use oil for lube just  Like any other drill. Once they heat up they will
dull like yours did. I have done alot of work with them, and the oil make the cut faster and the saw last longer.
Post by: Bobzooki on April 19, 2004, 03:21:01 AM
Oh, yeah - that would have been so much fun, trying to squirt oil on the belly armor, STILL ON THE VEHICLE!  I can see it now, oil in my eyes, in my hair, in my mouth.
Did I say that I'm lazy, and don't want to drop the armor to do this???
Post by: jagular7 on April 19, 2004, 08:32:09 AM
You could have brought the hole saw to Moab, and I bet someone there would have done it for 3 beers and a few bites of your meeaaalllllssssss.
Wait till your next oil change, get prepared with a remote oil filter setup, and the valve thingy, and install all that when you do an oil change. Only difference you won't have the magnetic drain plug.
Post by: Bobzooki on April 19, 2004, 09:19:17 AM
Remote Oil Filter???  There IS such a thing?  I would KILL for that on my wife's Grand Vitara!!!
