ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: cwright on April 02, 2012, 07:41:39 PM
Will a 97 sidekick transfer case work in a 88 Sammi? Thinking positively......If so what do I need to swap to make it work?
No
What Sidekick65 said. :)
The sidekick transfer case doesn't have a high-range reduction like the Sammy ones does, if you want to run dual T-Cases you need a Kicker3 style setup. Then use the Tracker 5-speed as well as a 1.6l. It's a bit of work but pretty cool once you get it setup.
Ive heard that OTT are no longer producing anything. correct me if im wrong
