ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: randy mohawk on April 08, 2012, 05:48:05 AM
Title: steering play
Post by: randy mohawk on April 08, 2012, 05:48:05 AM
My steering  has never been tight  on my 87 sammy with  31" tires , even though it has A drop pitman arm with new tie rod ends and drag link for high steering .The steering wheel has play, if I held my hand at 12 o'clock I could turn it to close to 2 o'clock and back to almost 10 o'clock without moving the  wheel . What can be done to tighten it up and get a more direct feel?
Title: Re: steering play
Post by: airdale navy on April 08, 2012, 08:40:41 AM
If it is like the sidekick,there is a nut on top of the steering box .With a stud with a screw slot .Hold with a screwdriver and break nut loose.Turn in clockwise.Then re-tighten holding  with the screw driver.Turn about 1/4 at a time and recheck.Do not over do it.
Post by: Jonny Rash on April 08, 2012, 08:56:10 AM
As Airdale stated, that is the way to adjust the free play in the steering box. Years ago I read that you need to have a friend turn the steering wheel as you remove the freeplay at the box, otherwise you can possibly damage the box. I believe that it can bind, if you don't crank the wheel while it is adjusted.
Also, check the steering coupler. Unbolt it and inspect it for tears. I recently had one that was literally ripped throughout, but it was not visible with it installed.
A panhard bar will also help a lot.
Post by: randy mohawk on April 10, 2012, 12:35:48 PM
Thanks Airdale for the right advice , I put just a tad more than a 1/4 turn and all is well with my steering no more white knuckles. Also it would probably be a good time to check and  top off your steering box oil.
Post by: Warn Industries on April 10, 2012, 01:11:06 PM
Very timely thread. I was just thinking about doing this on my 'Kick.
- Andy
Post by: bentparts on April 10, 2012, 02:43:04 PM
I've been wanting to replace the ragjoint in my steering for a long time but the hardware seems to be frozen, couple that with the turbo sitting right there and I just keep ignoring it. I know it needs attention, just need to get on it. Thanks for the good tips on steering adjustments.
Post by: airdale navy on April 10, 2012, 04:25:10 PM
Glad I could help.
