ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Tracy Donoho on April 12, 2012, 12:42:53 PM
When did Suzuki start putting fuel injection into the Samurai? I have a 88 and have found an 88.5. I have not got to look at it yet. If it is stock will it have fuel injection? Why two different models for the same year?
1990 - removed two of four spider gears from front differential
- wheelbase increased an inch or two (inorder to improve the ride)
- added FI (fuel injection) to 1.3L engine, increased horsepower to 66
- tranny and tranfer case bearings changed to the sealed design
this link should give you all the info you need.....
http://en.wikipedia.org/wiki/Suzuki_Jimny (http://en.wikipedia.org/wiki/Suzuki_Jimny)
1990 is correct for the first year for EFI.
Suzuki actually removed 2 of the 4 spider gears in the front carrier in 88.5s (although 88.5s were generally a mix and match of parts....so some had 2 spider gear front carriers and others had the older 4 gear style).
The wheelbase never changed....it is 79.9"....86-95 samurais. They did change the rate of the rear springs at some point though, to improve the ride (I think it was in 88.5).
[url]http://en.wikipedia.org/wiki/Suzuki_Jimny[/url] ([url]http://en.wikipedia.org/wiki/Suzuki_Jimny[/url])
Wikipedia is generally a pretty good source of accurate info. But it isn't always true. For example, they say, "A new 1.3 4-cylinder engine with throttle-body fuel injection was introduced with 66 hp (49 kW) in September 1991." Which is obviously wrong. The 1990 model year samurais were the first ones with throttle body EFI.
