ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: robbyrob on April 21, 2012, 12:40:58 PM
Title: weber carb swap check engine light
Post by: robbyrob on April 21, 2012, 12:40:58 PM
so i just got my weber carb on and i was wondering if my check engine is going to stay on because i am no longer running the electric carb?
Title: Re: weber carb swap check engine light
Post by: robbyrob on April 21, 2012, 12:49:44 PM
also if you have done this swap and can tell me what i need to do to fix this that would be grate
Post by: ack on April 21, 2012, 06:56:10 PM
The easiest way to fix that problem is to remove the ECM.   It's been so long since I installed my Weber that I can't recall if the Check Engine light came on afterwards.
I hope that this helps!
Post by: rascott on April 21, 2012, 07:03:36 PM
yes
the check engine light will stay on.
removing the ecm will kill it.
i have done this.
Post by: robbyrob on April 22, 2012, 01:45:40 AM
what about passing smog here in Oregon they check to make sure that the check engine light works I was thing about putting a diode in the alternator charging line and running a solenoid to the check engine light but i cant find a diode in the right size
