ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: stanekb on April 27, 2012, 09:58:26 PM
Title: Toyota axels?
Post by: stanekb on April 27, 2012, 09:58:26 PM
Anyone know what needs to be build, bought and or modified to put in Toyota axels?
( I am wanting to do this because the 82 SJ is hard to find parts, do I want to go with more common front and rear axels, if you have any other suggestions I'm all ears!)
Title: Re: Toyota axels?
Post by: Boxcar on April 28, 2012, 05:57:48 AM
CJ 5 axles require much less modification to swap into a Sammy. Aspecialy pre 71 s. They are nearly a direct fit.
 Corect off set and width.   ...Boxcar...
Post by: stanekb on April 28, 2012, 07:34:25 AM
Post by: Drone637 on April 30, 2012, 02:55:53 PM
Are you looking at putting a new motor in as well?  If your just looking for slightly larger axles with easier to find parts I would track down a set of Samurai axles.  That will give you disk brakes in the front, access to a lot more locker options and they are 3" wider then your stock SJ-410 axles.
You will need to re-weld your spring pads but they can be made to work with your stock springs without to many issues.
Post by: stanekb on May 01, 2012, 12:49:59 PM
Perfect, thanks
