ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: chopper on April 15, 2004, 06:08:16 PM
ok so my truck decided to have a really ruff idle, i checked and cleaned the distributer, spark plugs and my egr valve.and still is ruff
what are soem things that i can check to see if they are the problem to this??
1992 geo tracker 1.6L 8 valve engine
My 16V has spontaineously idled rough twice since I bought it. Both times it was a plug wire.
Fuel filter? Bad Gas? How many miles? Is it possible your timing belt jumped a tooth?
well there are 226k kilomerters on the engine, i did the timing belt about 20k kilometeres ago i was thinking fuel filter too, but wouldn't that effect my driving performance too?
thanks for the quick replies
Yeah, you would probably have driving issues, too.
I would think that even the spark plug wire would cause driving issues... How's the air filter?
Id check your compression. I bet you have a burnt valve. :-/
