ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: zuki1018 on June 22, 2012, 10:24:30 AM
Title: 16v Cam: Mine is "I" up, keyway down?
Post by: zuki1018 on June 22, 2012, 10:24:30 AM
(http://www.suzuki-forums.com/attachments/suzuki-sidekick-escudo-vitara-geo-tracker/13493d1332799875-timing-belt-cam-cog-aligned1w.jpg)
I know what its supposed to be however, my cam sprocket is mounted backwards.  How does this affect valve timing... they are obviously not exactly 180 degrees apart.  Apparently I didn't notice this last go around... but the engine did run ...and good as far as i could tell lol.
This is a used head so no telling the history.
Title: Re: 16v Cam: Mine is "I" up, keyway down?
Post by: fordem on June 22, 2012, 10:56:38 AM
I don't think it doesn't make the slightest bit of difference - what's important is the position of the cam, relative to the crank - there are two keyways and one is 180* away from the E (Exhaust) mark, whilst the other is 180* away from the I (Intake) mark - if it'll make you happy, unbolt the cam wheel, pull it off, reposition it and put the bolt back in.
Post by: zuki1018 on June 22, 2012, 10:59:42 AM
Yeah ...that does make sense. Guess i will sleep better tonight knowing its correct!
