ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: huff on July 16, 2012, 08:50:16 AM
I'm in the process of swapping my 1.3 for 1.6 8v . I have a Thorley header and trail tough adapter being shipped. I want to buy a weber carb also . seems to be a lot of options, such as water choke ,electric choke, manual choke etc. Would a k601 be a good choice.
Thanx Huff
None ;D If your putting in a 1.6 8v why not use the TBI? IF your set on a carb, get a Myside with HD carb.
[/quote
Yes I looked into the myside Zor kits . its a 12 week wait. I cant wait that long. Whats TBI. If its the original fuel inj. and manifold your refering too . I just have the 8v donor engine with no ecm or wiring harness.
Another question. Do I use the distributor that came with the 8v or do I have to use the distributor off the 1.3.
Thanx
Huff
If you really want a weber, I have one ill let go for 100, comes with base plate, air filter, carb and a 1.3 manifold.
