ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Flatlander on July 25, 2012, 03:32:03 PM
Can someone help me understand the gear process when i run larger tires? I have 5:12 stock gears. i am running 33 inch tires. My question is, which way do i have to go in gears to get closer to the factory? Feeling a bit dumb here for asking. Thanks
your wanting to go towards a 5:62 ratio.
Thanks. i appreciate this. Any idea what they might be found in that would fit in my stock diffs?
they are kinda hard to find and spendy if you do find them, there are some for sale on this site but they come from a 1989 4 door with an eight valve 1.6 I think, if you go lower to like a 5.89 you will have to go to a ford nine in the rear or some kind of a dana, I think calmini still has the front ring and pinions.
Calmini USED to sell 5.83's They work GREAT for 33's. I had them on the Gnewt.
There are few options for a tracker/sidekick without swapping axles front and rear to Toys or dana units, would be to install an undertaker and run the much stronger 4.30 R&P's or go with a sammi TC with 6.5 gears.
There may be 5.71 R&P's available in the future, but when is the real question.........
This may help you in your gear quest. These are the ratios found by year in the different models. Nice to have if you are looking for 3rds from a Pick & Pull....
89 2dr 1.3L carb 5speed man. 5.625
89-95 2dr 1,6L TBI 5speed man. 5.125
89-95 2dr 1,6L TBI 3speed auto. 4.625
91 4dr 1.6L TBI 3speed auto. 4.625
91 4dr 1.6L TBI 5speed man. 5.375
92-98 4dr 1.6L MPFI 5speed man. 5.125
92-98 4dr 1.6L MPFI 3speed auto. 4.30
92-98 4dr 1.6L MPFI 4speed auto. 5.125
94-98 2dr 1.6L MPFI 5speed man. 5.125
94-98 2dr 1.6L MPFI 3speed auto. 4.30
94-98 2dr 1.6L MPFI 4speed auto. 5.125
96-98 X90 1.6L MPFI auto or man. 4.625
4.625 gears have an 8/37 tooth count
4.30 gears have an 10/43 tooth count
5.125 gears have an 8/41 tooth count
5.375 gears have an 8/43 tooth count
5.625 gears have an 8/45 tooth count
