ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: bordurlin on July 27, 2012, 04:18:58 PM
Hey y'all. New guy from Alabama here. I have a '96 Tracker 4X4 with a standard transmission. The clutch pedal has a rod attached to it that's threaded on the end where the clutch cable attaches to a bracket. This bracket has a square hole that fits on the square shoulders of the rod, just past the threads. A nut holds the bracket in place. Mine broke where the threads start, so I'm looking for a replacement clutch pedal that has this threaded end. My problem is that I've bought two and neither had the threaded end, but had a splined end. Does anyone know if it's just the '96 that had the threaded end? And, does anyone have one available for purchase???? If so, email me at bordurlin|removethispart|@bellsouth.net. Thanks.
I think the threaded rod is 96-98.............
I've been looking for a threaded pedal for about 2 months??????????? Good luck
Other years have the splined end..........
Give Samurai Salvage or Trail Tough a call. I believe you can swap the entire pedal assembly between models.
