ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: somersetzuk on August 02, 2012, 06:22:38 PM
Title: Lifting my ZUK!!
Post by: somersetzuk on August 02, 2012, 06:22:38 PM
I am thinking about using the YJ missing link kit in the front of my zuk. An 4 linking my rear  and stretching my wheel base to 100" all way around. Any thoughts or words of wisdom will be much appreciated. Thanks
Title: Re: Lifting my ZUK!!
Post by: somersetzuk on August 02, 2012, 06:30:16 PM
Also could i just stretch it with the Yj springs with out 4 linking it?
Post by: tombstone on August 08, 2012, 02:04:36 PM
Hmmmm...no words of wisdom here... ???
Post by: 86samurai829 on August 11, 2012, 03:32:28 AM
you can stretch the rear as much as you'd like bc you are 4 linking it. but the front you wouldnt really be able to stretch at all without moving all of your spring brackets.(ones attached to the frame). and then if you stretched it to 100" it would look kind of funny being stretched way out in the rear and nothing in the front. i would have to say stay at stock WB or close to it until you can 3 or 4link the front as well. then all you would have to do is remake your rear 4link bars and shock hoops and you could be at 100" without it looking funky. it could be stretched more evenly
Post by: somersetzuk on October 07, 2012, 08:36:56 AM
Thanks for the info.
