ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: Jakezuki on August 13, 2012, 09:31:07 PM
Title: keep or scrap that is the question
Post by: Jakezuki on August 13, 2012, 09:31:07 PM
i bought a 92 sammi for what i thought was reasonable about 3-4 months ago drove it for 3 days and thats it i swopped efi to a weber carb and had ecm rebuilt first problem was the fuel issue and i fixed that with the carb setup and drove it for 3 days then lost spark so i had ecm rebuilt because i knew that was the fuel issue from the start figured it probably shorted in another spot causing no spark but it did not fix the problem any ideas and is there anyone near me that would let me borrow there ecm to try and make sure the rebuild was even succesful on me ecm and i could also use a schematic for the ignition system thx for the help
Title: Re: keep or scrap that is the question
Post by: FireCkrEd on August 14, 2012, 06:04:47 AM
Jake,
   Have you tried Suzuki-Forums.com ?  there are a couple guys there who can help diagnose your problems.
Post by: Skyhiranger on August 14, 2012, 10:50:12 AM
Who did you have rebuild the ECM?
Wiring diagrams can be found at suzukiinfo.com
The ECM going bad can cause a no spark issue.  But it can also be caused by a bad ignitor, distributor, or coil.
Post by: ack on August 14, 2012, 03:45:47 PM
You swapped FROM EFI to Weber?
If so, you don't need the ECU.
Please clarify...
Post by: Rhinoman on August 15, 2012, 04:44:59 AM
Please clarify...
maybe for timing control?
What fuel pump is this vehicle running? an EFI pump will totally overwhelm the float in the Weber.
Post by: Rhinoman on August 15, 2012, 04:48:11 AM
The Suzuki Samurai EFI supplement can be downloaded here:
http://www.rhinoman.org (http://www.rhinoman.org)
Post by: Jakezuki on August 15, 2012, 08:01:11 PM
i did the carb swap it ran for 3 day and died no spark sent ecm to someone from the forum with good bacground put it in and still no spark
Post by: zorproducts on August 17, 2012, 08:13:22 AM
As mentioned you can not use an in tank pump with the Webel. Way to much pressure. Without sounding like I am insulting you I won't even ask why go from EFI to a carb that won't work on angles.  On your model you do need an ECU to read the halo effect to fire the TBI. With the TBI removed and not having a spark indicates you may not have 12 v at the coil and distributor.
Have you checked the ignition fuse? Located on the lower bank of fuses. factory is 15 amp red fuse. Bad fuse= no voltage going to coil or distributor. A simple check with key on should get you a 12v reading on the black/white wire going to coil pack and distributor (same wire). I have seen some weird issues were the fuse is good but with the fuse block removed so I could read voltage on the back busses, no voltage coming out on the black/white wire. Bent the tabs on the fuse to dig into the buss and then got voltage. Hope it is something simple for you to fix.
MY
Post by: Jakezuki on August 17, 2012, 08:09:19 PM
i have an inline regulator to knock the pressure down and it has power to the coil it is not sending a signal to fire the plugs and i swapped it to carburetor because the ecm was bad and it was $200 cheaper to get the carb setup and know it would run than hope it would run with anothere ecm
Post by: fordem on August 18, 2012, 10:27:14 AM
Can you get a "stand alone" distributor from a carbed Sami to replace the one you have now?
