ZUKIWORLD Model Specific Suzuki Forum => Suzuki Sidekick, Vitara, Geo Tracker (Gen. 1 Platform) 1989-1998 => Topic started by: chadstichter on September 02, 2012, 11:38:07 PM
it has a fresh rebuilt 1.6 16v with only 250 miles on it and it is extreamly gutless. i thought it they were just like that but then i drove a buddys and it is lifted even more with 31s also and it darn near lights them up. i was wondering if any one knows anything that i could to help it. i already have a k&n and i took the plumbing out that goes from the air box to the fender stuff. if anyone knows any other upgrades besides a turbo it would help
thanks
A 2" exhaust is needed.
Also, even though the engine is freshly rebuilt, do a compression check.
Stock cam?
yeah it has a stock cam i couldnt find anyone to machine mine or a aftermarket one to put in it has a calmini header and a exhaust is comming soon. will no cat help i live in a place where smog doesnt matter
I only know of two places that advertise high lift cams for the 16v SOHC engines, Suzukird and Zukination, the Suzukird is a complete valvetrain so it is big $$$, the Zukination/Altered Ego cam is a regrind that has the maximum amount of lift as possible without moddified rockers.
Play with your timing a bit. On mine when I switched motors I had to switch to running it 2 degrees advanced over stock before it would run well. Strange as the old motor ran with timing dead on.
okay thanks
so i did a compresion test today cylinder 1: 155lbs 2: 155lbs 3: 155lbs 4: 130lbs anyone know why
Add a little oil into the sparkplug holes and retry the compression test(this is called a wet test), also it sure wouldnt hurt to do a leakdown check. #4 does seem to be low in compression, could be rings, valve seat or even too much clearance on the valve lash.
whats a leak down check i havnt heared of that? i will put a little oil on there tonight and try it again
I would guess that the vakve timing is out. For a cam try SuperF1y on teamswift.net, he has a number of different grinds.
