ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: nimrodsman on September 16, 2012, 08:33:36 PM
Title: Weber 32/36 DGEV
Post by: nimrodsman on September 16, 2012, 08:33:36 PM
I have an 87 samuri and am going to put this weber on this weekend. I have a set of adaptor plates for and issuzu came off a Chev LUV. Will it bolt up or will I need any thing else? Plan to put it on this weekend and do not want to start with out all the parts I need. Thanks for any advice you can give
Title: Re: Weber 32/36 DGEV
Post by: nimrodsman on October 22, 2012, 11:07:51 PM
All in and running--do have a slight vacuum leak under the mounting plate. Took back off and cut new gaskets and now running fair. Still have high idel might still be a slight leak. Does give more bang for the buck than the stock. Thanks for info from all who gave me help
Post by: zuki1018 on October 24, 2012, 09:28:42 AM
Congrats!
Next steep hill you climb when the float chokes out your fuel supply, flip the carb 180 so it least it does it down hill!
