ZUKIWORLD Discussion Forum => Classified Ads => Topic started by: SIDEKICK65 on September 21, 2012, 12:18:40 AM
Any one have any used 4.24:1 transfer case gear's for a sidekick or should i buy the Undertaker?
well, your talking about 2 totaly different things here.... the undertaker is a BEFORE transfercase under-drive that reduces your final drive ratio. think of it as just lowering ALL of your gears.. HIGH AND LOW
the sidekick/tracker 4.24:1 DOES NOT reduce high range, it only reduces your low range gearing. THIS ONLY REDUCES LOW
I think the problem your trying to adress is hiway driving, correct? If so , the proper answer is the undertaker , brent says it brings you back to stock gearing with 33" tires......with that in mind, REMEMBER..tire size will still effect the performance of these things reguarding of the gearing..ROLLING MASS has a BIG EFFECT on a 98 HP motor!
Yes i know the transfer case only effects low range.if i buy the undertaker should i still buy the transfer case gear's as well or will i been ok with the undertaker.
oh, in that case....
it can never have too low of a low range IMHO(well, i'v see some marlin stacks that you were like WTF???..but they dont count)
My rig is a daily driver and i use it for hunting and play in the snow.if i can save money by just getting the undertaker and not transfer case gear's ill do that.but i just mite put a toyota 2.7 motor in it now.Im kicking the motor swap around strong.
65
Have you wheeled a rig that has the xfercase gears ? I was looking hard at yota cases thinking I needed a lower final ratio, mines 88 to 1 with the 4.2 gears and It's almost too low in 1st. at 3500+ rpm it's going 2.7 mph with 33's. one problem is it doesnt want to pull the 33's on the highway very well. Im trying to get setup where I tow most of the time so it wont be a problem.
Ed
I take it trying to find a transfer case with gear's already installed is hard to find.
I will have one for sale in the spring if you can wait that long.
How much are you gonna ask for it?
I know the x case gear's only help you in low range but thats all i use if im in 4 wheel drive.Are the gears worth the money or do people think there a waiste of money??
I found a used sidekick t case with the 4.24:1 gears and yoke eliminator.I can get it for $450 and is that a decent deal?
$450 is a pretty good deal for that setup, as long as its in ok condition.
I really like the 4.24's in my Sidekick... And I'm only running 30" tires.
Plus, a twin stick setup is nice addition as well. :)
Yes its in good shape.the gear's only been install about a yr.
Get it! 8)
The t case will be here monday. Now i need to buy a locker for the samurai front end and some 5.38 gear's.after that in doing exhaust and call it good for now i hope :-\
Nice!
