ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Wildman on September 29, 2012, 06:57:27 PM
I have a 1.6 8V tracker engine in my 88 Samurai. I assume it has the stock 1.6 pump and bracket. My problem is the pump is to close to the steering shaft and has rubbed a hole into the supply line. The pulley is about 1/16" from the steering shaft spline where it clamps onto the steering box. Is there an easy fix for this or do I just need to fabricate a new bracket that relocates the pump above the steering shaft.
Wade
On mine I put another stock bracket above the other bracket it bolted to the block and then I welded the two together for a little added strength it was to be a temp kind of thing that was ten years ago.lol
Yea, I could see how that would work. I will try to fab a whole to bracket later today and see how that works out.
Thanks for yout input and help
Wade
Most people move the pump up (move the bracket up on the block).
