ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: sniper4x4 on October 27, 2012, 07:03:27 PM
my front and back seats are shot in my 88 zuki what is a common, easy, and cheapest route to go.
Alot of people use the seats from a Dodge Neon. They fit good and are comfortable. Thats what is in mine.
Wade
Wade
X2. For front seats, the later neon seats are great. I have them in a couple of my samurais.
For the rear seat, you are kinda limited on choices, since a samurai rear seat is so narrow. So basically a samurai or some jeeps have a narrow enough rear seat, to fit between the fenderwells.
For teh rearseat, a Jeep fold and tumble is the best way to go. You can either source a good used one or buy a new one from Corbeau, Best top or one of the others.
I have a budy trying to sell a fold and tumble from his old jeep. Still in good shape, grey with brackets I believe. I can find out how much he wants for it. About $33 to ship via USPS.
Rob
will a sidekick rear seat work? not sure what year it is out of but the guy said its latch was in-set in the floor were mine is bolt to the top. Are the neon seats a bolt in swap or will i need to make brackets? I found a set of cherokee seats how hard would would they be to make work in the front?
I just swapped in some JK seats. It wasn't hard at all...I just measured and drilled for the Samurai sliders. I mounted the sliders a couple inches forward so I could get more leg room. So far so good...Swapping Cherokee seats would probably be similar.
I have a pair of grey rear seats for the samurai in great condition. $50 plus shipping from Virginia 24590.
I have 91 Honda Prelude front seats in mine... it was a bit of work though.... used the seat pans from a 86 Honda CRX
they are very comfy, have memory seat that does'nt use power to do that..,. has lumbar and the side of the drivers seat also is adjustable
I have seats outta a early 90s f150 in mine. I had to pull 1 arm rest off of each seat. I used the sammys lower seat bracckets.
