ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: SIDEKICK65 on October 30, 2012, 09:55:33 PM
I got my t case to day with the 4:24:1 gear's :) It came with the Slip Yoke Eliminator that has double bolt pattern.so what im asking is what the bolt pattern fit's.I was going to have a drive line made and needed to know.
they are the small and large pattern Sami bolt patterns
you could pick up a 1990 samurai or newer front or rear drive line and have the tube made to order. I think it is the same pattern for toyota but the hole in the center is a tiny bit larger than a sammie. not sure what you have, take it by walker an see if he has one laying around.
