ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Alaska101 on March 29, 2004, 11:02:34 AM
Is there anyway of testing the injector to see if it is working or geting power from the ecu???
My zuki stoped on me a if i pour gas in it it will run so the problem is fuel.
Thanx
get a "noid" light at an auto parts store. They're cheap enough. Plugs into the injector connector and flashes to indicate ECU and wiring is working. I have also heard some people use LED's in place of the noid lights. I have never tried this, though.
hot wire the fuel pump, then hit the injector
(quickly) with 12V jumped from the battery,
or if you know how to test with a multi-meter
check if the injector has an Ohm reading, if
it does not, the injector is bad/gone, if it does
have a reading, which it probably does it's the
EFI Computer.
