ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: lucszuk on March 29, 2004, 08:14:00 AM
Title: cheapo lifto
Post by: lucszuk on March 29, 2004, 08:14:00 AM
i have an idea fopr a cheap 4 inch lift. it is that you would use 4 inch longer shackles and instead on only using shackles u would extend the actual hangar and then brace it a bit so u would get a true 4 inch lift and your camber caster and stuff would be the same
opinions on this would be greatly appreciated as i have not done it or seen it done i just might do it on my lwb sammi
Title: Re: cheapo lifto
Post by: idaholwb on March 29, 2004, 09:10:40 AM
 Just do a spoa and get it over with. You are like an 'oser friend of mine, and you over analize things, try to make something "cheaper" work.
The spoa would be much easier and more beneficial.
Post by: lucszuk on March 29, 2004, 09:17:04 AM
i know that?? i have done spoa's on every sammi ive had but i was just seeing if there was anyother ways i could do it and i found someone that did that and it handled liek shit so ime doing a shackle reversala nd 3 inch ome springs  and a spoa
