ZUKIWORLD Discussion Forum => Classified Ads => Topic started by: bentparts on August 29, 2015, 09:49:14 AM
All of my Trackick parts hoard up for sale, by part or if someone wants to make an offer on everything and come by and pick it up I am certainly open to that. Smaller stuff shipped, big stuff pick up. SOMEONE MAKE ME AN OFFER ON EVERYTHING AND BRING A TRUCK! :laugh: There are way too many pics to post so if interested I'll send you a pic of item, just include your email. ALL ITEMS IN VERY GOOD CONDITION, CLEAN AND READY TO INSTALL.
1. Set of used Corbeau sport seats in good condition. Black Fabric, no mounts, drivers seat missing inside ( next to console ) plastic cover. $100
2. Front wheel seal set NIB. $10
3. 13" Grant padded black leather steering wheel with adapter and mounting hardware $30
4. AC control modules $10 ea.
5. Crank Shaft seal saver kit NIB $5
6. 1" Driveshaft spacer $10
7. power steering and water pump pulleys $ 10 for both
8. MAF UNIT and COIL $70 both
9. Extended bump-stop set, new never used with extensions and rubber bump stops $30
10. Stock braced idler arm, NEW. $25
11. Halogen head light bulb set $10
12. NEW front control arm bushing set for both sides front and rear $35
13. NEW Drivers side window regulator $25
14. NEW coolant hose set $25
15. Oil filter sandwich plate with pressure sending unit and AN fittings for pressure gauge or turbo feed $20
16. ECU with mount and all relays for 3 speed auto trans $75
17. Calmini Ceramic coated header and down pipe, includes donuts and NEW gasket $150
18. Trans or PS oil cooler $20
19. 2 Spal electric fans 14" and 6 " both $25
20. winch fairlead and 3/8ths cable 100 ft. $30
21. Trackick front bumper skin, with inside styrofoam block and lower rad plate. VGC $30
22. 16V intake system complete needs cleaning $45
23. 4 cleaned and tested 16V injectors stock, $50
24. Console padded armrest cubby with storage and cup holders ( home made but nice ) $35
25. My spares box, kydex with steel corners. Lockable and strong.
EVERYTHING ON THIS LIST BUT THE WINCH FAIRLEAD AND CABLE, STEERING WHEEL AND ADAPTER, OIL COOLER, BUMPER SKIN, SEATS, INTAKE SYSTEM AND CONSOLE FITS COMFORTABLY IN THIS SPARES BOX AND WEIGHS ABOUT 60 LBS TOTAL. I'LL PACK IT ALL BACK IN AND SHIP THE WHOLE THING TO YOU MAKE OFFER.
26. Remanufactured 16V engine ready to drop in with NEW everything inside, Includes valve cover freshly painted and installed, distributor and new wires, cap and rotor installed, oil pan freshly painted and set up with turbo AN10 oil drain. ( includes AN 10 cap ) installed, dipstick installed, everything needed to finish including gasket set and NGK iridium plugs. Everything to hook it to an auto trans, flywheel and adapter, trans plate, etc, finish gasket set with new exhaust ss steel gasket, manifold gasket, etc. First $1000 takes it.
27. Transfer case with Calmini 4 2 1 crawler gears and twin sticks. Includes interior cabin boot panel and shifter boot. Twin stick shifters with screw on extensions for those with body lifts. First $400 takes it.
28. Stock transfer case with 63K on it. $75
29. 3 buckets of stock take off accessories: PS pump, AC compressor, ALT, intake system etc, Everything $30.
Everything + shipping to your address.
Pics of any and all stuff sent to you at your email upon request. Again, someone willing to take everything and pick up I will make a KILLER DEAL and help you load it! This would be a great way upgrade a tired Trackick. Feel free to share this post too.
Easiest to reach me by text 856-816-4647, please include item info. EVERYTHING LOCATED NJ 20 MINUTES OUTSIDE PHILLY.
which engine dose the header fit and would you ship it to me in Salem
Fits a 1.6 16 Valve Bob and of course I'll ship it. It's not too heavy so it shouldn't be very expensive. Paypal is fine. Give me your zip code and I'll get you a shipping quote if you want. $29 to your zip Bob.
more stuff
Pics of seats?
The shop Zip is 97317
I just got home from work Bob, I'll get that quote for you tonight. Thirty Nine:
more seat pics, wear on drivers seat, typical from climbing in and out.
more stuff
ECU for 3 speed auto 16V 1.6
more stuff
more stuff
and more
and more
injector set
more
more
Wish you lived closer, darn it. That's a great price.
Yeah, I hear ya. shipping to Portland would kill it. I may have the engine and all the engine related stuff sold. I'll know for sure on Monday.
ENGINE, HEADER, INTAKE, COIL AND MAF, ECU, CUBBY ARMREST, SEATS, PULLEYS SOLD. Still have extended bump stops, new never mounted, used set of Doetsch Tech shocks for a lifted Trackick, complete set of new control arm bushings for both sides F+R NIB, front wheel seal kit, new braced idler arm, trans cooler,electric fans, winch fairlead and cable, 4 2 1 Calmini geared T case with twin sticks, stock t case, Grant wheel and adapter kit, 4 good cleaned 16V injectors, a never installed set of 600 LB Suspension Specialist front Trackick coils. One does have a part of the bottom trimmed off to make a pigtail. A few other odds and ends. ACCEPTING ANY REASONABLE OFFERS. Will try and ship anything than can fit USPS priority for quickest and fastest delivery. 1 WEEK AND IT'S GOING ON EBAY.
hey bud ,you still got that REBUILT 16v 1.6L ?
See above. Thanks. EVERYTHING ELSE STILL AVAILABLE. Tcase has been gone through and thrust bearings and main shaft bearings replaced. READY TO INSTALL.
Tcase, bump stops, idler arm, wheel seal set, bushing set, steering wheel and adapter, seal savers, window regulator and shocks SOLD!!!
Still have a low milage stock Transfer case, trans cooler, winch fairlead and cable, electric fans 14" and 6", Good, clean engine fan, and 3 Air Conditioning control modules.
Do you have any 95 to 98 soft top trim molding
Sorry, do not. I had a tintop anyway.
do you still ahave the wheelbearing kit and the braced idler arm?
If yes can you give me a price plus shipping to zip code 41144?
Travis
I have a Superwinch model EPi9.0S - 9,000 lbs/12V winch that has the cable fowled about 50 feet into the spool. This Superwinch model was discontinued a couple years ago and I can't find any specs on the internet on the actual size of the steel cable that it uses, other than the diameter of the synthetic rope used on the same model was 3/8ths diameter. Rope is usually a little stronger than similar cable, so I can't just assume 3/8ths steel would work.
I think your wire cable you have for sale would work for my application, but I am not at all positive. Do you have any experience/knowledge with these Superwinches that could shed light on this?
Thanks,
Norm
Travis
Hey Travis, Physically, yes but I did take a deposit on a bundle of stuff that included. If that somehow falls through I'll let ya know. Thanks.
Thanks, Norm.
Hi Norm, unfortunately I have no experience personally with the Superwinch brand of winches other than hearing there a pretty good value. This was the stock cable and fairlead that came on my Warn, that I replaced with rope for it's lighter weight. I can only tell you it seems pretty stout, was never kinked and has no damage. Hope that helps.
Alright, I will attempt to find more detailed tech info on the cable version of this Superwinch beast. If I find the 3/8ths line works (thickness and connector end) and you still have it available for sale, I will contact you again and take it off your hands.
Thank you.
Norm
Everything gone but cooler, cable and fairlead (pending?) good set of stock 16V injectors, couple of cam seals and various top end gaskets including a new valve cover gasket. Also have a good set of used 1.6 16V valves and some other small valve train parts. If anyone is interested and can come by and pick em up: I have the original seats, black, fronts and rear bench. (Not a split rear seat but all in vgc,) rear belts and a bunch of different seat covers (all red and black.) some also to big to ship parts like a front bumper cover with insert and rad guard also in vgc. FREE, come and get em.
Send me the cooler!!
(gratis, lol)
sent from an anus from an asus
Cover the shipping John and it's yours.
Sounds good. Just let me know what I owe you Mike...
Ps- I built a buggy so now you can come wheel with my samurai at Rausch Creek... We will throw em both on my goose neck...
PM me your address John and I'll drop it FedEx. I'd be happy just to ride shotgun. Besides I haven't driven a stick off road in like forever! :laugh:
Bentparts - Thank you for the fast shipping and making sure the parts were packed well. Everything arrived safely and was waiting on me when I got back.
Could you provide freight cost for the winch cable and fairlead to 47356, please.
Thank you,
Norm
