ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Mike71 on March 22, 2004, 10:24:52 AM
Title: lets talk- cooling fans
Post by: Mike71 on March 22, 2004, 10:24:52 AM
i have seen a few storys of people smashing down into a water hole and bending or breaking the fan.
i have also seen a few where the fan has torn up the radiator even with the flex fans
so what i was thinking is can i mount an electric fan that has an on off toggle switch in the cab so if i am going to go down through some water i can shut it off??
not going to do this anytime soon i am just reasearching and putting things on my ..need to buy list
i plan on saving all the money i need then paying for half of the stuff with a no interest credit card..so it shouldnt take that long
thanks for any info =)
Title: Re: lets talk- cooling fans
Post by: 1bigtracker on March 22, 2004, 11:36:21 AM
if you dunk a electric fan in water too many times it will die.
Post by: jerryp58 on March 22, 2004, 11:38:23 AM
Sounds like a good plan.
I've been thinking about doing the same except since I don't do much off roading I wasn't planning on a cutoff switch (I could just unplug the power to the thermostat switch if I was getting in deep water).
You'd need the fan (depth will be important - I think I only have about 3-1/4" tops on my '90 Tracker, and you don't want it to draw too many amps if you have the wimpy stock alternator like I have), a thermostat switch (preferrably adjustable), and I guess a toggle switch that you can run between the hot lead and the thermostat.
Hopefully someone who has done it will chime in and confirm or refute this info.
Post by: Mike71 on March 22, 2004, 12:31:02 PM
well the stock alt isnt going to stay with me much longer lol since ill be running a winch and stuff ill need a bigger alt..so ill do the gm alt braket swap and run a 200amp alt
why would dunking the elec fan to many times mess it up? shouldnt they be water profed like the computer?
Post by: 1bigtracker on March 22, 2004, 01:05:16 PM
i don't think you could really water proof it with out really getting into builting everything.  all the heat the motor makes will melt plastic so i dunno.
Stu
Post by: Mike71 on March 22, 2004, 01:13:56 PM
yah but shouldnt it come water proof? they make those things for 4x4s they should know atleased one brain child is going to get into water above the doors  ;D
Post by: 90Stomper on March 22, 2004, 01:29:36 PM
i just got a flex-a-lite fan from 4wd.com and will be instaling it when i put my motor in in 2 weeks and will post here to let you know how it fits etc.  they also sell 'be-cool' fans (more $$), neither says anything about being (or not being) water proof.  but it will get wet in the rain right. :-/  for me it shouldnt be a problem though.  i too am going to get the gm alt bracket as i put the motor together.  what alt are you going to use that has 200 amp?  will it have the same size shaft for the pully?
o, the fan was the smallest one they had for $99.95 plus 30 for the switches etc.  the be cool ones are to big i think and are $199
i think this flex-a-lites #, give em a call and ask
1.800.851.1510 ex108
Post by: Mike71 on March 22, 2004, 01:46:13 PM
hey thanks for all that info..i havent really looked into the alts yet
i forgot though theres a place that will make alts for our engines..i may go that route if u want info i can get it
Post by: Speedracer7c on March 22, 2004, 02:08:28 PM
How much is the GM Alt bracket?
Post by: Mike71 on March 22, 2004, 02:33:25 PM
the GM alt braket i saw was if i remember right 24.99? 29.99 plus shipping
i cant find the web site though so i am still looking
Post by: jerryp58 on March 22, 2004, 08:47:31 PM
I'd like to see the Website for the alt bracket too.  Is there any down-side to running a higher amp alt?
BTW, I've seen some electric fans advertised on eBay (so take that for what it's worth) that say they're water-proof.
Pics of the alt install and the fan install would be great!
Post by: Rhinoman on March 22, 2004, 10:33:13 PM
Kenlowe (a British make so I don't know if they're available over there) do electric fan conversions. They list heavy duty and waterproof as options. Pretty expensive over here though, maybe a lot cheaper in the US.
Post by: Bobzooki on March 22, 2004, 11:48:43 PM
That's odd.  Never had a problem with my Kick.
It has a plastic fan, and a liquid filled clutch.
When I splash it in the creek, it just spins at whatever speed it can, but never hit anything, or broke.  Not like you NEED a radiator fan, when the radiator's in the creek...
Post by: Speedracer7c on March 23, 2004, 01:21:49 AM
hahahah, I don't think Kick's are marine creatures!!  ;)
Post by: Bigzook on March 23, 2004, 05:13:32 AM
Not on a kick but bolth my sammies have electric fans. I have never had a problem with them being wet. One of them has been on for about 3 years no problem. As for cost, if youre willing to spend some time at a wrecking yard alot of newer cars have great fans. Look for front wheel drive cars,the newer the better. Also removing that fan and clutch will gain you a little high end horsey's, and your motor will spin up faster.
Post by: Mike71 on March 23, 2004, 07:17:31 AM
ok i will deff make a better effort at finding that site again since i have had a few requests..it might take me a while i think last time i found it took me a few days of searching
the only thing i could see to running a high amp alt is..size..and also itl take more power to turn so u might want to do that and the K$N filter at the same time to make up the tinny bit u losse
Post by: Mike71 on March 23, 2004, 07:18:43 AM
do all trackers have water filled clutchs??if they dont then theres no reason for an elec fan right? aside from the fact that it wouldnt strain the engine to have an elec fan
hmmm decisions decisions
Post by: Bobzooki on March 23, 2004, 07:35:00 AM
Yes, as far as I know, they do (and it's not water in the clutch - that would freeze).
Wouldn't strain the engine?  Now there's a misconception!  Kick a high current load on, and watch your engine bog down!  Electricity isn't free, you have to create it with the alternator, and yes, your battery stores it up, but as soon as you start drawing it down, the voltage regulator demands more current to charge it back up.
The conversion of mechanical force (the engine roatating) into electricity (the alternator) is NOT 100% efficient.
The conversion of electricity (in the battery, replenished by the alternator) into mechanical force (spinning the fans) is NOT 100% efficient.
You LOSE POWER (in the form of heat mostly) at each step.  What that means is, you actually use MORE power from the engine with an electric fan, than you do with a direct-drive mechanical fan - the BENEFIT is that the electric fan can switch on and off, and the mechanical fan is always on.  If the electric fan is on more than about 60% of the time, you're actually using MORE power to run the electric fan, than the mechanical fan.
Post by: Mike71 on March 23, 2004, 07:53:50 AM
thats true..i just will have power to burn while the winch and other things (stereo) isnt on
doesnt an elec fan shut off at over 40mph orsomething like that?
Post by: 90Stomper on March 23, 2004, 10:03:08 AM
i will take pics when i install my fan, but i will have to send them to someone to post - no www :'(
my mech builds stock cars and suggested the el fan for more hp on my 4 cy engine, i agree with the loss of power by draw logic, but this should be resolved by an alt with more amps.  which should not take more power cause you will have to use the same size pully,  well it might turn harder...
watch where you get a fan, cause there are thermotic switches involved and the size on our cars radiators are pretty small.  size IS an issue here ;)
i saw an gm alt bracket at http://www.trailtough.com for $24 or so.  but i need to call them cause its listed for a sammy.  and i read somewhere (?) that you will need to put in a slightly bigger fuse with a bigger amp alt.  and i looked at some 92 amp gm alts the other day at an auto el shop, where the guy told me NOT to try to amp up my alt, and the gm one was pretty much the same size as mine.  but it only had one bolt bracket on the bottom...
read someone used a pontiac 6000 alt in a sidekick but the stock pully had to be reamed out, why has no one figured out the right combo of alt to do this....or is that what we are doing ;D
and.... the fan i got (and the one in my g/f 2003 sport track) are controled by radiator temp.  not mph.  i think they all work this way.
Post by: Mike71 on March 23, 2004, 12:56:34 PM
it would be less of a strain though wouldnt it? ur alt only spins as much as it is going to it doesnt get harder to spin when u draw from it does it? so in a sense u take the fan off of the engine and run it using the electricity u are already priducing anyway...right??
Post by: lil_Truck on March 23, 2004, 01:02:57 PM
Nope, if you weren't using any electricty at all.  All the power you will use is just to spin the alt.  The more power you use the harder it is to turn.
Think of a gas generater.  If you ever seen one operate, the engine has to work harder to produce more electricty.
Post by: Mike71 on March 23, 2004, 01:10:27 PM
oh..see id dint know that i thought the alt just spun at one speed....
that makes more sense otherwise if u have a 200amp alt theres alot of power being wasted
nvm im slow  ;D
thanks for the info though
Post by: 95XL7 on March 23, 2004, 01:34:37 PM
I'm running dual 12" electric fans with an adjustable thermostat. When they kick in i can barely tell,the motor doesn't drop any rpm's. Their also pretty quiet.
(http://images.snapfish.com/33%3A32%3C9523232%7Ffp45%3Dot%3E2329%3D585%3D374%3DXROQDF%3E2323475%3C45465ot1lsi)
Post by: lil_Truck on March 24, 2004, 12:58:19 AM
You also almost have a full liter more of engine also.  About a 1/3 more.
Post by: Bobzooki on March 24, 2004, 01:45:35 AM
Bobzooki's first law of Automotive Physics:  Nothing is free.
If you have a MORE EFFICIENT alternator, it will produce more power for a given load on your engine.  Guess what?  Nobody is trying hard to make a more efficient alternator.
So, if you take out an 80 amp alternator, and put in a 100 amp alternator, it's gonna be harder to turn when you're drawing full power.  That's a bigger load on your engine.
So, you say, when the electric fan kicks on, the RPM's don't drop.  That's because of two things.  (This is hypothetical.)
1.  A 5 amp draw on an 80 amp alternator isn't exactly going to break the bank - it'll take a little more force to turn it, but not THAT much.
2.  When the fan turns on, it draws its initial current surge out of the battery, and the alternator load gradually increases as the battery voltage is drawn down (and the voltage regulator demands more current to charge it back UP).  So, you would notice it a lot more, if the battery wasn't there.
You could try this experiment:
Start the engine, and disconnect the battery, so you're running entirely on the alternator.  Turn on the fans (rig it).  Now you will se the ACTUAL draw that fan puts on the electrical system.  The battery just softens the blow.
Post by: mavapa on March 24, 2004, 04:38:22 AM
The advantage of electric fans is that they are not on at all when the engine does not need additional cooling. That means that the fan is not on when you're driving down the highway. However, if you're creeping down some rocky trail on a hot summer day, the fan is likely to come on at least occasionally as the engine gets hot. Although there is efficiency loss in generating electricity etc to run the electric fan, there is also loss - sometimes significant loss - in spinning a fluid clutch fan. The fan wants to turn at engine speed. Any time it spins at less than engine speed, it's turning mechanical energy into heat. That's just lost power.
Post by: lil_Truck on March 24, 2004, 06:50:49 AM
Here in Michigan it's all mud.  I wish it wasn't, it just get tirersome having to wash it all the time.  Anyway, electric fans just don't seem to hold up to that kind of abuse around here.
My 2cents
