ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: captwoody on December 22, 2015, 07:08:01 PM
Title: fuel cutoff reset
Post by: captwoody on December 22, 2015, 07:08:01 PM
Does a 01 tracker 2.0 2dr 4x4 have a fuel reset switch for when you are in a collision? and if so where is it ? I was at an accident today and one of my fireman hit that switch on a car that was in an intersection so a lady could drive away. Then I thought to myself I don't know if I have one or where it was at.
Title: Re: fuel cutoff reset
Post by: fordem on December 23, 2015, 03:49:28 AM
It doesn't have one - the ECU senses when the engine stops and shuts the fuel pump off after a few seconds.
Post by: captwoody on December 23, 2015, 01:17:14 PM
Thanks Fordem I could not find one ,and after it is activated would not be the time to look for it. Since it is in my ECU do I wait for it to reset or use my OBDII to reset if it is activated
Post by: fordem on December 23, 2015, 02:13:17 PM
There's no resetting - if the engine stops, for whatever reason, the ECU shuts the fuel pump down - when you turn the key to the start position to restart the engine, the ECU turns the pump back on - if the engine does not start, it'll shut the pump off again; if the engine restarts the pump will stay on.
